02-01-2011 12:15 AM
Good day.
I have got LMS 3.2 (DFM 3.2.0).
My router 3900 Series (RFC1213-MIB::sysObjectID.0 = OID: CISCO-SMI::ciscoProducts.1041) in DFM is unknown device.
In others modules of LMS (CM, RME and others) is OK.
Why?
Help please.
02-01-2011 05:38 AM
Too bad
it is marked as not supported.
Cheers,
Michel
02-01-2011 06:04 AM
Sorry, but I can't open this URL...
Error 403- Forbidden File or Application.
Can you help me and to past here some part of this html page?
02-01-2011 06:19 AM
I was fooled by the table that doesn't fit on my screen
I thought it said not supported but I was a coulumn off
Apparently there is an update you can download from CCO
You need a cco login of course
Device Type Device Name / Modules Supported sysObjectID / Vendor Type Minimum Software Supported Version (CM) Topology (CM) VLAN Mgmt (CM) LANE Mgmt (CM) VNM (CM) User Tracking (CM) Supported Version (DFM)
DFM1.x Class (DFM)
Supported Version (RME) Inventory (RME) Config Mgmt (RME) Software Mgmt (RME) Package Name (CV) Package Version (CV)
Cisco 3900 Series Integrated Services Routers Cisco 3945 Integrated Services Router 1.3.6.1.4.1.9.1.1041 15.0(1)M [RME, CM] 5.2 (Device Updates 4.0)7 Yes NA NA Yes NA 3.2 (DeviceUpdates 2.0)26 Not Supported 4.3 5 Yes Yes Yes Rtr3900 1.1
26. DFM Device Update for this specific device support is available at:http://www.cisco.com/public/sw-center/index.shtml.
Cheers,
Michel
02-01-2011 06:32 AM
Thank you, Michel.
