Saving running-config in one command
jderrien
Community Member
Hi there,
I'd like to copy a running-config to a tftp server without having the router to prompt me to confirm for the server IP address and filename. Any idea on how to do that ?
Thanks and regards
Jean-Marc
ebreniz
Level 11
Level 11
I have not come across any command like that , I think you can make a TCL script in router and make it do so..
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/fun_r/frprt2/frd2001.htm#1021855
bricknera
Community Member
copy system:/running-config
then you just tap enter twice. Let me know.
Brick
milan.kulik
Level 11
Level 11
To avoid any prompting using 'copy run' (to start or tftp) use the global config command 'file prompt quiet'. This will then allow you to do single line saves.
