DHCP between router and firewall
gabelz
HI all,
i've DCHP server configured on FW eth1/4 and static IP on router interface Gi0/0.
Which configuration i should apply to ROUTER-EDGE in order that PC4 could receive IP address from FW DHCP server?
Thanks in advance,
MG
you should use helper address
https://www.ciscopress.com/articles/article.asp?p=1574301&seqNum=7
Good luck
KB
gabelz
Hi Kasun,
thanks for reply.I did already and not working:
FW port eth 1/4 ip address 2.2.2.2/24
DHCP server conf on FW
on EDGE-ROUTER:
interface GigabitEthernet0/2
no ip address
ip helper-address 2.2.2.2
duplex auto
speed auto
media-type rj45
Gateway of last resort is 2.2.2.2 to network 0.0.0.0
S* 0.0.0.0/0 [254/0] via 2.2.2.2
2.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 2.2.2.0/24 is directly connected, GigabitEthernet0/0
L 2.2.2.50/32 is directly connected, GigabitEthernet0/0
on PC4> ip dhcp
DDD
Can't find dhcp server
MG
