DHCP Distribution Issues
I tryed to distribute DHCP address with the server1 but pc1 and pc2 are not in the same vlan than pc0 could someone help me plz...Réseau complet.PNG
R1:
Current configuration : 1240 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R1
ip cef
no ipv6 cef
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.10.2 255.255.255.0
ip helper-address 192.168.10.1
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.20.2 255.255.255.0
ip helper-address 192.168.20.1
interface FastEthernet0/0.30
encapsulation dot1Q 30
ip address 192.168.30.2 255.255.255.0
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
ip address 10.1.1.1 255.255.255.252
clock rate 128000
interface Serial0/0/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router rip
version 2
passive-interface FastEthernet0/0
network 192.168.10.0
network 192.168.20.0
network 192.168.30.0
no auto-summary
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
SW8:
Current configuration : 1564 bytes
version 12.2
hostname Switch
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
switchport access vlan 10
switchport mode access
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
switchport access vlan 20
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
switchport access vlan 30
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 0060.3ed1.1601
no ip address
interface Vlan20
mac-address 0060.3ed1.1602
no ip address
interface Vlan30
mac-address 0060.3ed1.1603
no ip address
line con 0
line vty 0 4
login
line vty 5 15
login
end
luis_cordova
Hi @SamuekBedard0585
Try this changes.
The gateway IP must match the IP configured in the subinterfaces:
In the DHCP pool change the default gateway:
For vlan 10:
192.168.10.2
For vlan 20:
192.168.20.2
For vlan 30:
192.168.30.2
PD: If you want to attach the PKT, you must first compress it (winzip) and then attach it :)
luis_cordova
Try this changes.
For vlan 10:
192.168.10.2
For vlan 20:
192.168.20.2
For vlan 30:
192.168.30.2
