3750X netflow configuration.
I have a 3750x switch stack and i want to know if I can configure flexible netflow with it.Do i need to upgrade the IOS?
#sh ver
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 09-Feb-12 18:14 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
FR-PAR-JAC-PRODTECH-01 uptime is 44 weeks, 5 days, 6 hours, 24 minutes
System restarted at 13:28:52 CEST Sat Jan 12 2013
System image file is "flash:/c3750e-universalk9-mz.122-55.SE5/c3750e-universalk9-mz.122-55.SE5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750X-48 (PowerPC405) processor (revision F0) with 262144K bytes of memory.
Processor board ID
Last reset from power-on
3 Virtual Ethernet interfaces
1 FastEthernet interface
104 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : E4:D3:F1:C7:B1:80
Motherboard assembly number     : 73-12552-06
Motherboard serial number       :
Model revision number           : F0
Motherboard revision number     : A0
Model number                    : WS-C3750X-48T-S
Daughterboard assembly number   : 800-32727-03
Daughterboard serial number     :
System serial number            :
Top Assembly Part Number        : 800-31326-03
Top Assembly Revision Number    : B0
Version ID                      : V03
CLEI Code Number                :
Hardware Board Revision Number  : 0x04
Switch Ports Model              SW Version            SW Image
*    1 54    WS-C3750X-48       12.2(55)SE5           C3750E-UNIVERSALK9-M
     2 54    WS-C3750X-48       12.2(55)SE5           C3750E-UNIVERSALK9-M
Switch 02
Switch Uptime                   : 44 weeks, 3 days, 9 hours, 38 minutes
Base ethernet MAC Address       : E4:D3:F1:CC:3A:80
Top assembly part number        : 800-31326-03
Top assembly revision number    : B0
Version ID                      : V03
CLEI Code Number                :
License Level                   : ipbase
License Type                    : Permanent
Next reboot licensing Level     : ipbase
Configuration register is 0xF
NAME: "1", DESCR: "WS-C3750X-48"
PID: WS-C3750X-48T-S   , VID: V03  , SN:
NAME: "Switch 1 - Power Supply 0", DESCR: "FRU Power Supply"
PID: C3KX-PWR-350WAC   , VID: V02  , SN:
NAME: "Switch 1 - FRULink Slot 1 - FRULink Module", DESCR: "FRULink 10G ST Module"
PID: C3KX-NM-10G       , VID: V01  , SN:
NAME: "TenGigabitEthernet1/1/1", DESCR: "SFP-10GBase-SR"
PID: SFP-10G-SR          , VID: V03  , SN:
NAME: "TenGigabitEthernet1/1/2", DESCR: "SFP-10GBase-SR"
PID:                   , VID:      , SN:
NAME: "2", DESCR: "WS-C3750X-48"
NAME: "Switch 2 - Power Supply 0", DESCR: "FRU Power Supply"
NAME: "Switch 2 - Power Supply 1", DESCR: "FRU Power Supply"
NAME: "Switch 2 - FRULink Slot 1 - FRULink Module", DESCR: "FRULink 10G ST Module"
NAME: "TenGigabitEthernet2/1/1", DESCR: "SFP-10GBase-SR"
TIA,
Nicos Nicolaides
TIA, Nicos Nicolaides
jakewilson
Hello Nicos,
Does your 3750x has the C3KX-SM-10G module?  I believe you need it to export flows.
Jake
10 Replies 10
jakewilson
Hello Nicos,
Jake
Nikos
When I checked the guide for NetFlow on 3750 I found this note
Flexible NetFlow is supported only on the Catalyst 3750-X and 3560-X switch running the IP base or IP services feature set and equipped with the network services module. It is not supported on switches running the NPE or the LAN base image.
So from an IOS perspective you are fine and should not need to upgrade your IOS. I am not clear whether your 3750 has the network services module that they describe.
Here is the link that I was using if you want to check it further
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/15.0_1_se/configuration/guide/swmnetflow.html
Rick
Rick
OK, it seems that i need the C3KX-SM-10G module instead of the C3KX-NM-10G i currently have.
I would advise that even with that module, trying to get useful Netflow data on a L3 switch is often an unsatisfying endeavor. There are a number of limitations and caveats and they vary model to model and across IOS releases.
If at all possible in your environment you are much better off extracting Netflow data from a router.
Hi Jake
I am having the same module C3KX-SM-10G but still I am not able to configure the netflow. Can you please guide me on it,
Manik
I just had to go through this and I created a post with step by step instructions on how to get this to work.  I needed to setup NetFlow for several VLANs and used a SPAN to mirror them over to an interface on the C3KX-SM-10G.  We also had to create a loopback cable to get the fiber SFP to come up.  Hope this helps!
please suggest command to check availability of  C3KX-SM-10G module in the switch.
"show inventory" is the command. It also shows up in "show version"
please suggest the command to check  C3KX-SM-10G module
Can the C3KX-NM-10G export flows, or does it have to be the C3KX-SM-10G?
