DHCP how to block a MAC Address
avives
I have a Cisco SG300 serving DHCP.
I want to block a device with MAC address that is plugging on my network.
How can I deny one or a list od MAC addresses ?
Thanks for helping me.
Albert
6 Replies 6
Mark Elsen
 - In essence you can't use DHCP to block a mac address because DHCP is a 'volunteering service' that a device either chooses to use or not.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Jitendra Kumar
Try this command drop the traffic per vlan.
Hope this command will work on the SG 300 Series
       Switch(conf)#mac address-table static 3408.0499.981c  vlan X drop
Jitendra
Jitendra
How can I run this command ? I cannot find the CLI option .
Is it reversible ?
How can I roll back the command if the MAC needs to connect finally ??
Thank You Jitendra
below is the command for remove.
no mac-address-table static mac_address vlan vlan-id
Thanks.
Jitendra
Jitendra
follow
