difference between Cisco Network Assistant and Configuration Assistant
gflorescu
I'm a little confused about the difference between the Cisco Network Assistant and the Cisco configuration assistant.
http://www.cisco.com/en/US/products/ps5931/
http://www.cisco.com/en/US/products/ps7287/index.html
I'm not sure when you would use one or the other. It seems that both of them can be used to configure devices.
aborole
mostly similar applications, but config assistant is SMB product targeted towards smart business communications systems and supports only those device types like UC5XX/CE5XX and few routers etc
