1182
difference between Cisco Network Assistant and Configuration Assistant
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
09-07-2007 08:32 AM
I'm a little confused about the difference between the Cisco Network Assistant and the Cisco configuration assistant.
http://www.cisco.com/en/US/products/ps5931/
http://www.cisco.com/en/US/products/ps7287/index.html
I'm not sure when you would use one or the other. It seems that both of them can be used to configure devices.
Labels:
- Labels:
Network Management
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-07-2007 08:36 AM
mostly similar applications, but config assistant is SMB product targeted towards smart business communications systems and supports only those device types like UC5XX/CE5XX and few routers etc
