Difference between Cisco router and Cisco firewall command (NAT)
Rishi.WWN
Hello Everyone,
I hope and wish, you all are doing very well. Further want to know the difference between cisco router and cisco firewall commands. Kindly let me know with some command like NAT, default route etc.
Rishi
the differences are many. Below are a few examples:
ASA
--> this is a pool of NAT addresses
object network NAT_POOL
range 192.168.2.100 192.168.2.120
object network LAN
subnet 192.168.1.0 255.255.255.0nat (INSIDE,OUTSIDE) dynamic NAT_POOL
IOS
ip nat pool NAT_POOL 192.168.2.100 192.168.2.120 netmask 255.255.255.0
ip nat inside source list 1 pool NAT_POOL
access-list 1 permit 192.168.1.0 0.0.0.255
ASA
--> this is static NAT
object network STATIC_HOST
host 192.168.1.1
nat (INSIDE,OUTSIDE) static 192.168.2.1
access-list OUTSIDE_TO_INSIDE extended permit tcp any host 192.168.1.1
access-group OUTSIDE_TO_INSIDE in interface OUTSIDE
On the ASA, everything needs to be specifically allowed (that is why you need the access list above), on an IOS router, everything is allowed by default...
IOS
ip nat inside source static 192.168.1.1 192.168.2.1
ASA
--> this is the default route
route OUTSIDE 0 0 ip_address_next_hop
IOS
ip route 0.0.0.0 0.0.0.0 ip_address_next_hop
