cisco nxos syslog configuration
hello every body
i try to configure syslog client on my cisco 3064 nexus switch by this command
#logging server 192.168.3.250 5 use-vrf management facility syslog
#logging monitor 6
bu nothing is send to my syslog server.i have 5 more 2960 and they are working fine. but none of my nexus device are sending or generating syslog message.
what is the mistake ?
Mark Elsen
      - FYI https://bst.cloudapps.cisco.com/bugsearch/bug/CSCua92174
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
when you using "use-vrf management" is this VRF aware how to reach syslog server ?
try ping 192.168.3.250 using source use-vrf management
BB
yes, the server respond
as-media-R22# ping 192.168.3.250 vrf management
PING 192.168.3.250 (192.168.3.250): 56 data bytes
64 bytes from 192.168.3.250: icmp_seq=0 ttl=127 time=7.134 ms
64 bytes from 192.168.3.250: icmp_seq=1 ttl=127 time=0.845 ms
64 bytes from 192.168.3.250: icmp_seq=2 ttl=127 time=0.85 ms
64 bytes from 192.168.3.250: icmp_seq=3 ttl=127 time=1.38 ms
64 bytes from 192.168.3.250: icmp_seq=4 ttl=127 time=1.31 ms
--- 192.168.3.250 ping statistics ---
5 packets transmitted, 5 packets received, 0.00% packet loss
round-trip min/avg/max = 0.845/2.303/7.134 ms
as-media-R22#
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
