Disabling SNMP link UP down for a single interface
srimural
is there a way to disable snmp up/down messages for single interface on a router.
Sri
yjdabear
Assuming you meant the SNMP linkUpDown trap messages, yes, you can control that per interface via:
[no] snmp trap link-status
by default CiscoWorks does not alert on up/down of access ports. Only trunks, uplinks and wan links.
In our parallel sytem HPOV it seemed to have an issue with the up/down links and the person for that system went in and did a no snmp trap link status on every interface. So now when trunks or uplinks go down. we dont know about it.
I say this only as a caution as to which interfaces you want "managed" in cw.
Yep. I got it yesterday... my intention is to avoid this ISDN VOICE interface which goes up n down for each voice call to be removed from sending traps for that...
Thanks for the input again..
have enabled both in the sense..
no snmp trap link-status
no logging event link-status
Srinath M
+91 99809 30364
