DiskWatcher popup window question?
getwithrob
Level 3
Level 3
How can the disk watcher utility that monitors disk utilization be disabled.
It's unfortunate the utilization can't be raised or lowered from the default setting of 80% utilization on a filesystem. If anyone know's how to modify this parameter, please let me know.
Thank you, Rob
nhabib
Level 9
Level 9
I'm on vacation, thus do not have access to CiscoWorks
In any case, it's probably a process that you can stop.
Do a:
/opt/CSCOpx/bin/pdshow | grep -i diskwatcher
and once you have the correct syntax (case), you may issue:
/opt/CSCOpx/bin/pdterm diskwatcher
On vacation! What the hec are you doing still looking at and answering the forum?
I know there's a way to turn it off 'cause when I doing LMS for the DC gov't, I opened a TAC case and was able to get it off completely even when the application was brought down and back up. Unfortunately, I didn't document it!
Well, you would probably have to edit the /opt/CSCOpx/objects/dmgt/dmgtd.conf and stop / start daemon manager
Of course, make sure you make a copy of the original
