DMVP and DSVP combo
zeeshanzahid510
What issue can we face if we are using DSVPN (Huawei Router) at HUB side and DMVPN (Cisco Router) at Spoke side?
I am working in a corporate based firm having more than 1000 branches connected to Head Office.
Currently our scenerio is we are using DMVPN at Hub and Spoke Sites.
We are moving towards Huawei Routers means DSVPN at HUB side but our mostly branches are running cisco routers means (DMVPN At Spoke Side).
Kindly share any tips and Links which will be helpful to look after for above scenario.
Migrate to flexvpn which i think both vendors support it.
Thanks. It will be helpful, if you can share issues which can be faced between DMVPN and DSVPN communication.
I have been reading through the Huawei DSVPN configuration documentation, and it looks like it is fully compatible with Cisco's DMVPN implementation, as both use NHRP and other standard, non-proprietary protocols. The only thing Huawei does not seem to support are PFS groups. And (obviously) you cannot use EIGRP, but if you use RIP/OSPF/BGP, you should be fine.
