Internal error when running basic Ansible playbook
s.day
I have a playbook to gather facts from cisco switches and routers.  The playbook works on the switch in my lab but fails with an internal error message on the router.  I have tried several other playbooks against the router and no matter what I'm trying to do I'm getting internal error.  I'm using Ansible version 2.9.19 python 3.
Playbook:
- name: "PLAY 1: Collect Device Facts"
  hosts: stage1
  tasks:
    - name: "P1T1: Gather Device Facts"
      ios_facts:
    - name: "P1T2: Write Device Facts"
      blockinfile:
        path: ./facts.yml
        create: yes
        block: |
          device_facts:
          {% for host in play_hosts %}
          {% set node = hostvars[host] %}
            {{ node.ansible_net_hostname }}:
              serial_number: {{ node.ansible_net_serialnum }}
              ios_version: {{ node.ansible_net_version }}
          {% endfor %}
          all_loopbacks:
          {% if node.ansible_net_interfaces is defined %}
          {% if node.ansible_net_interfaces.Loopback0 is defined %}
            - {{ node.ansible_net_interfaces.Loopback0.ipv4[0].address }}
          {% endif %}
          {% endif %}
          {% endfor %}
      run_once: yes
      delegate_to: localhost
Playbook output:
The full traceback is:
WARNING: The below traceback may *not* be related to the actual failure.
  File "/tmp/ansible_ios_facts_payload_pBtPYN/ansible_ios_facts_payload.zip/ansible/module_utils/network/common/network.py", line 229, in get_capabilities
    capabilities = Connection(module._socket_path).get_capabilities()
  File "/tmp/ansible_ios_facts_payload_pBtPYN/ansible_ios_facts_payload.zip/ansible/module_utils/connection.py", line 185, in __rpc__
    raise ConnectionError(to_text(msg, errors='surrogate_then_replace'), code=code)
fatal: [stage-1]: FAILED! => {
    "ansible_facts": {
        "discovered_interpreter_python": "/usr/bin/python"
    "changed": false,
    "invocation": {
        "module_args": {
            "auth_pass": null,
            "authorize": null,
            "gather_network_resources": null,
            "gather_subset": [
                "!config"
            "host": null,
            "password": null,
            "port": null,
            "provider": null,
            "ssh_keyfile": null,
            "timeout": null,
            "username": null
    "msg": "Internal error"
Any help would be appreciated. The router is a
Francesco Molino
Is it failing for all routers on only some of them? Have you tried running just for few to validate?
Also, can you validate your ansible_connection is network_cli instead of local? (this change ansible_connection generates some common issues referenced on multiple thread on github if you search for that specific error)
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
andymagana
This looks like a while ago but did this get resolved I am using Tower and we have CIMC C240 M5's.
