DNAC Serial number
OseiAsibey
Our DNAC box is miles away. I have been browsing the GUI->Inventory to find the serial number but no luck. Can anyone tell me how I can find the serial number of this DNAC box?
This will give you the serial of the chassis if you drop it into the DNA CLI. It will require the maglev password.
sudo cat /sys/devices/virtual/dmi/id/chassis_serial
8 Replies 8
justinbodie
Level 4
Level 4
I had the same issue.  You can pull the hardware information through SSH to Maglev by using the "sudo lshw" command.
ssh x.x.x.x -p 2222
$ sudo lshw
maglev-master-1
description: Rack Mount Chassis
product: DN1-HW-APL
vendor: Cisco Systems Inc
version: A0
serial: FCHxxxxxxxxx
Thanks - this is great.  To anybody that follows, do this instead - you'll save yourself a lot of scrolling!  (All the bits you need from the output are right at the start...)
sudo lshw | head
Cheers,
Richard
Thank you.
This made it for me.
Cheers
Atila
Hello guys. In our DNAC is one PSU broken.
We have to open an RMA case. How can i get this info under:
What file shows me, what is the serial of the broken psu?
thx a lot
Since, this was only provided a CLI option as an answer, for GUI go to the "help" on the upper right hand side of the GUI and click "about". You'll see the serial number there.
mcaraba
Ismael's post is the easiest way to get the SN.
