When using the ncs cleanup command in PI What will be erased?
CCC3
I apologize for writing again with similar content.
What things are deleted when using the ncs cleanup command on pi?
Can you tell if the contents of the drawings or equipment set in the pi will also disappear and what logs will disappear?
Mark Elsen
  - It will give a series of info's of what will be deleted before 'final confirm' ; your drawings will not be deleted ,
 M.
Do you know any documents or contents that detail what will be deleted?
