PI GUI not accessible Related PI /opt, /var100%.
CCC3
I was informed by the customer that the pi's gui is not access.
I checked and found that /opt and /var were 100% used.
In relation to this, it is necessary to check how to delete and what information is deleted when deleted.
Please note that since this is version 2.2, you cannot receive help from TAC.
  - Start looking in /var/log and /var/tmp ; files in there can be safely deleted for /opt look for logging related files and or directories  and delete older logfiles (>1month)  but keep the directories ; do not wipe them completely
 M.
Mark Elsen
 - In that version you can still get (linux) root access and clean up the filesystems (remove unnecessary files) : login to the CLI with the admin account ; then issue the command  sudo -s
 M.
How do I know if a file is unnecessary?
 M.
