Does cisco ASA supports ARP related MIBs
xhu000001
Hi there,
Does cisco ASA support to reveal arp related MIB (IpNetToMediaEntry , IpNetToPhysicalEntry, CiscoInetNetToMediaEntry). How can I collect the IPs that ASA has ARP records via SNMP. Those three OIDs are what I am using to collect ARP entries on Cisco router and switches. Is there any other proprietary OIDs for this purpose in ASA?
Thanks.
Liam.
AFROJ AHMAD
Hi Liam,
unfortunately that MIB is not supported .
Enhancement BUG is there:
CSCtn81697    Add support for an ARP MIB on ASA
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Vinod Arya
Most of the ASA's dont support IP-MIB, except some newer models like 5520 etc, that too on limited software versions.
You should share your ASA model and software details to check about this.
As far as the MIBs supported page for ASA doesn't mentions IP-MIB :
ftp://ftp.cisco.com/pub/mibs/supportlists/asa/asa-supportlist.html
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
