09-12-2005 01:08 PM
Does CNA work with 6509, 2980s, 2948s, 2948G-GE-TXs?
I can pick up my 3550's but none of the others. Any ideas? Thanks!
09-12-2005 01:19 PM
The CNA device supportlist is limited to specific switches running IOS. Looks like most of the ones listed above run CatOS.
09-12-2005 01:21 PM
Well the 6509 is running IOS. But it is acting as a router, would that make a difference?
09-12-2005 01:26 PM
CNA only support the devices listed at: http://www.cisco.com/en/US/products/ps5931/prod_release_note09186a008044c6eb.html#wp699844 and no, it do not support Cat6Ks
09-12-2005 01:29 PM
I don't believe that the 6500's are supported
Yes, I don't see them listed in the list:
http://www.cisco.com/en/US/partner/products/ps5931/prod_release_note09186a008044c6eb.html
09-12-2005 02:38 PM
they do list the 2940 series of switches. I guess they mean different ones than the 2948s? Or is there a IOS image for them?
