Does it exist web-UI about NX-OS?
jogilsang
hi!!!
i'm korean engineer
and i use N9K-C9508-B3 switch.
this is based on NX-OS
i want to find web ui.
but, i coudln't find
so i have a question
1. Does it exist web-UI about NX-OS ?
2. web-UI only assign in cisco IOS...?
   (for example : i attached my photo. this is my swtich 3850 webui)
if you give me good answer. i will give you point !!
Mark Malone
There is a gui for nx-os but its not free like ios/ios-xe SDM its the DCNM and its pretty expensive last time I checked , I think it was 10000 price list for 7ks
that's the only Cisco GUI available for nx-os
http://www.cisco.com/c/en/us/products/cloud-systems-management/prime-data-center-network-manager/index.html
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/prime-data-center-network-manager/datasheet-c78-736613.html
Prime DCNM is often thrown in for free with larger Nexus deals.
It's not built into the NX-OS though like the switch web UI is. It runs on a server of its own.
I've only seen it used in the largest customers - most small shops consider it more trouble than it's worth.
good! amzaing! very helpful. god bless you~
Thanks for reply. i readed your answer. and very helpful
