Don't using DFM - LMS 3.2.
Hi, I 'dont wanna use DFM, can I stop the processes or will cause some problem?
If I can stop the jobs, do I need to stop all jobs?
Common Services > Server > Admin > Processes
DfmBroker
DFMCTMStartup
DFMLogServer
DFMMultiProcLogger
DFMOGSServer
DfmServer
DfmServer1
Thanks.
Vinod Arya
if you dont want to use DFM at all, it is advisable to uninstall DFM components from LMS server. If that is not feasible, you can change the device manageability to auto and dont manage any devices in it which will have DFM virtually non-functional.
It is not suggested to play with the services, as they wont impact the server if none of the devices are managed.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
