dot3StatsDuplexStatus not firing from Cisco Switch
james_araujo
Anyone have any luck with this Trap dot3StatsDuplexStatus OID = 1.3.6.1.2.1.10.7.2.1.19
I am able to test the OID by doing an SNMP walk which shows the correct information, however no Traps are ever fired for this?
Here is my show running-config:
snmp-server host {ip-omitted} version 2c {community}
Vinod Arya
This OID is not a Trap and hence it would not generate one. If you see this OID :
Object dot3StatsDuplexStatus
OID 1.3.6.1.2.1.10.7.2.1.19
Type INTEGER
Permission read-only
Status current
Values 1 : unknown
2 : halfDuplex
3 : fullDuplex
The type is INTEGER. A trap would either have type as TRAP or if not TYPE it would show Trap Components.
You can check this document for some well known traps :
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a008021de3e.shtml
Or you can mention what trap you are looking for specifically.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
