Drops
athan1234
Level 3
Level 3
You apologize for my bad  english I am using google translate. I have a problem . My router  has drops, I can not understand this.
Switch Ports Model SW Version SW Image
* 1 26 WS-C3560V2-24TS 12.2(50)SE5 C3560-IPSERVICESK9-M
FastEthernet0/24 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 68bc.0c42.3a1a (bia 68bc.0c42.3a1a)
Description: Puerto_VLAN_Nacional
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 3/255, rxload 3/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 11w1d, output 00:00:04, output hang never
Last clearing of "show interface" counters 02:57:10
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 2265
Queueing strategy: fifo
Output queue: 0/0 (size/max)
30 second input rate 1347000 bits/sec, 422 packets/sec
30 second output rate 1253000 bits/sec, 447 packets/sec
6175344 packets input, 5810954285 bytes, 0 no buffer
Received 59777 broadcasts (56857 multicasts)
0 watchdog, 56857 multicast, 0 pause input
5027200 packets output, 1441609691 bytes, 0 underruns
interface FastEthernet0/24
Descripcion WAN
switchport trunk allowed vlan 115,911,1094
switchport mode trunk
switchport protected
load-interval 30
speed 100
duplex full
srr-queue bandwidth share 1 70 33 1
srr-queue bandwidth limit 90
priority-queue out
mls qos trust dscp
no cdp enable
end
show controlers
Transmit FastEthernet0/24
1105058391 Valid frames, too large
fomesekaca#show mls qos interface fastEthernet 0/24 statistics
FastEthernet0/24 (All statistics are in packets)
dscp: incoming
0 - 4 : 31029 0 0 0 0
5 - 9 : 0 0 0 7848010 53179
10 - 14 : 249 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 227135
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 379336 73752 0 0 0
45 - 49 : 0 617551 0 103186 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 87215 0 0 0
60 - 64 : 0 0 0 0
dscp: outgoing
0 - 4 : 33569 0 0 0 0
5 - 9 : 0 0 0 6792852 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 52677
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 1132360 0 0 0 0
45 - 49 : 0 222 0 0 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 25381 0 0 0
60 - 64 : 0 0 0 0
cos: incoming
0 - 4 : 22059 7903115 0 227135 0
5 - 7 : 1070639 103164 99256
cos: outgoing
0 - 4 : 5556 6820769 0 52721 0
5 - 7 : 1132648 0 25437
output queues enqueued:
queue: threshold1 threshold2 threshold3
queue 0: 1132358 0 0
queue 1: 6783584 56996 70658
queue 2: 52677 0 0
queue 3: 89167 0 0
output queues dropped:
queue 0: 0 0 0
queue 1: 6316 2 0
queue 2: 184 0 0
queue 3: 0 0 0
fomesekaca#show mls qos maps
Policed-dscp map:
d1 : d2 0 1 2 3 4 5 6 7 8 9
0 : 00 01 02 03 04 05 06 07 08 09
1 : 10 11 12 13 14 15 16 17 18 19
2 : 20 21 22 23 24 25 26 27 28 29
3 : 30 31 32 33 34 35 36 37 38 39
4 : 40 41 42 43 44 45 46 47 48 49
5 : 50 51 52 53 54 55 56 57 58 59
6 : 60 61 62 63
Dscp-cos map:
0 : 00 00 00 00 00 00 00 00 01 01
1 : 01 01 01 01 01 01 02 02 02 02
2 : 02 02 02 02 03 03 03 03 03 03
3 : 03 03 04 04 04 04 04 04 04 04
4 : 05 05 05 05 05 05 05 05 06 06
5 : 06 06 06 06 06 06 07 07 07 07
6 : 07 07 07 07
Cos-dscp map:
cos: 0 1 2 3 4 5 6 7
dscp: 0 8 16 24 32 40 48 56
IpPrecedence-dscp map:
ipprec: 0 1 2 3 4 5 6 7
Dscp-outputq-threshold map:
d1 :d2 0 1 2 3 4 5 6 7 8 9
0 : 02-01 02-01 02-01 02-01 02-01 02-01 02-01 02-01 02-01 02-01
1 : 02-01 02-01 02-01 02-01 02-01 02-01 03-01 03-01 03-01 03-01
2 : 03-01 03-01 03-01 03-01 03-01 03-01 03-01 03-01 03-01 03-01
3 : 03-01 03-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01
4 : 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 04-01 04-01
5 : 04-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01
6 : 04-01 04-01 04-01 04-01
Dscp-inputq-threshold map:
0 : 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01
1 : 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01
2 : 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01
3 : 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01
4 : 02-01 02-01 02-01 02-01 02-01 02-01 02-01 02-01 01-01 01-01
5 : 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01
6 : 01-01 01-01 01-01 01-01
Cos-outputq-threshold map:
queue-threshold: 2-1 2-1 3-1 3-1 4-1 1-1 4-1 4-1
Cos-inputq-threshold map:
queue-threshold: 1-1 1-1 1-1 1-1 1-1 2-1 1-1 1-1
Dscp-dscp mutation map:
Default DSCP Mutation Map:
5 : 50 51 52 53 5
show PLAtform POrt-Asic STaTs drop
Port-asic Port Drop Statistics - Summary
RxQueue 0 Drop Stats: 0
RxQueue 1 Drop Stats: 0
RxQueue 2 Drop Stats: 0
RxQueue 3 Drop Stats: 0
Port 0 TxQueue Drop Stats: 0
Port 1 TxQueue Drop Stats: 0
Port 2 TxQueue Drop Stats: 290932
Port 3 TxQueue Drop Stats: 0
Port 4 TxQueue Drop Stats: 0
Port 5 TxQueue Drop Stats: 0
Port 6 TxQueue Drop Stats: 0
Port 7 TxQueue Drop Stats: 0
Port 8 TxQueue Drop Stats: 0
Port 9 TxQueue Drop Stats: 0
Port 10 TxQueue Drop Stats: 0
Port 11 TxQueue Drop Stats: 0
Port 12 TxQueue Drop Stats: 0
Port 13 TxQueue Drop Stats: 0
Port 14 TxQueue Drop Stats: 0
Port 15 TxQueue Drop Stats: 0
Port 16 TxQueue Drop Stats: 0
Port 17 TxQueue Drop Stats: 0
Port 18 TxQueue Drop Stats: 0
Port 19 TxQueue Drop Stats: 0
Port 20 TxQueue Drop Stats: 0
Port 21 TxQueue Drop Stats: 0
Port 22 TxQueue Drop Stats: 0
Port 23 TxQueue Drop Stats: 0
Port 24 TxQueue Drop Stats: 0
Port 25 TxQueue Drop Stats: 3991103
Supervisor TxQueue Drop Statistics
Queue 0: 0
Queue 1: 0
Queue 2: 0
Queue 3: 0
Queue 4: 0
Queue 5: 0
Queue 6: 1456
Queue 7: 0
Queue 8: 0
Queue 9: 0
Queue 10: 0
Queue 11: 20
Queue 12: 0
Queue 13: 0
Queue 14: 0
Queue 15: 0
Port-asic Port Drop Statistics - Details
RxQueue Drop Statistics
Queue 0
Weight 0 Frames: 0
Weight 1 Frames: 0
Weight 2 Frames: 0
Queue 1
Weight 0 Frames: 0
Weight 1 Frames: 0
Weight 2 Frames: 0
Queue 2
Weight 0 Frames: 0
Weight 1 Frames: 0
Weight 2 Frames: 0
Queue 3
Weight 0 Frames: 0
Weight 1 Frames: 0
Weight 2 Frames: 0
Port 0 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 1 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 2 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 290715
Weight 1 Frames 58
Weight 2 Frames 0
Queue 2
Weight 0 Frames 159
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 3 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 4 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 5 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 6 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 7 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 8 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 9 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 10 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 11 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 12 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 13 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 14 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 15 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 16 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 17 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 18 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 19 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 20 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 21 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 22 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 23 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 24 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 25 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 3987417
Weight 1 Frames 3010
Weight 2 Frames 0
Queue 2
Weight 0 Frames 676
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 0: 0
Queue 1: 0
Queue 2: 0
Queue 3: 0
Queue 4: 0
Queue 5: 0
Queue 6: 1456
Queue 7: 0
Queue 8: 0
Queue 9: 0
Queue 10: 0
Queue 11: 20
Queue 12: 0
Queue 13: 0
Queue 14: 0
athan1234
Level 3
Level 3
     Transmit FastEthernet0/24                Receive
   1122533849 Bytes                       3888832379 Bytes
   2206121762 Unicast frames              2460059789 Unicast frames
       302885 Multicast frames              48101343 Multicast frames
          317 Broadcast frames               1865537 Broadcast frames
            0 Too old frames              2082319225 Unicast bytes
         2195 Deferred frames              233776748 Multicast bytes
            0 MTU exceeded frames          119394368 Broadcast bytes
         1808 1 collision frames                2363 Alignment errors
         1134 2 collision frames                2436 FCS errors
          800 3 collision frames                   5 Oversize frames
          556 4 collision frames                   0 Undersize frames
          436 5 collision frames                 931 Collision fragments
          448 6 collision frames
          433 7 collision frames                  12 Minimum size frames
          623 8 collision frames           749753942 65 to 127 byte frames
          701 9 collision frames           235693701 128 to 255 byte frames
          976 10 collision frames          130281996 256 to 511 byte frames
          368 11 collision frames          102321200 512 to 1023 byte frames
          131 12 collision frames          183042172 1024 to 1518 byte frames
           58 13 collision frames                  0 Overrun frames
           50 14 collision frames                  0 Pause frames
           21 15 collision frames
           82 Excessive collisions                 0 Symbol error frames
         1176 Late collisions                     10 Invalid frames, too large
            0 VLAN discard frames         1108938440 Valid frames, too large
            0 Excess defer frames                931 Invalid frames, too small
      1210930 64 byte frames                       0 Valid frames, too small
   1189975280 127 byte frames
    241435170 255 byte frames                      0 Too old frames
    129055219 511 byte frames                      0 Valid oversize frames
     51451287 1023 byte frames                     0 System FCS error frames
     39759766 1518 byte frames                     0 RxPortFifoFull drop frame
    553538328 Too large frames
