EEM and sending syslog trap
bmlakar
When using EEM applet or even EEM Script I have noticed a behavior, when sending syslog message like this
action 30.1 syslog priority notifications msg "Usmerjevalnik $_info_routername: 1G LINK 2 UP (sla id = $sla_id) !!!"
message does not appear in switch buffer and is not sent to syslog server, except when using global logging level "debugging" like:
logging buffered 1024000 debugging
logging trap debugging
Is this normal behavior?
I'm using C6513/SUP720/ios 151-2.SY2 or 122-33.SXJ6
Branko
AFROJ AHMAD
Hi Branko,
AFAIk, this is an expected behaviuor  , you need to have "logging trap debugging " command enabled to get the syslog traps.
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Afroz,
thank you very much for feedback and info provided.
All the best,
Branko
