CWM 15.3.00 don?t running on a station SUN with Solaris 9
TEDDY LLANO
The CWM 15.3.00 was installed on a station SUN FIRE V240 (CPU 1280MHz, RAM 4GB, 2 Disk 72GB, 8 GB SWAP). The station has the Solaris 9 and the Solaris patches recommended in the release notes for CWM 15.3.00.
When the command CWM (or start_SV+) is issued and the CWM CORE is started, we have the following error message:
terra$ start_SV+
Please wait CWM Processes are starting UP......
ILOG RT-Broker 2.300, licensed to "cisco-san jose, ca"
Error: ilblmap[620756995,1]@terra not registered.
Error: Failed to request logical mapper
After this, the initialization process stay looped back forever and the CWM Core never works.
There is no other product installed on the station SUN.
Teddy
David Stanford
Is DNS working properly? Can you do nslookup's forward and reverse for the hostname/IP?
Also, have a look at /usr/users/svplus/watchdog.conf
does it look like:
# process-name flag working-dir program-path program-arguments
ilblmap on . ilblmap
tftpmgr on . tftpmgr
snmpcomm on . snmpcomm
databroker on . databroker -b 19500
emsd on . emsd -b 19500
emd on . emd -b 19500
rtm on . rtm -b 19500 -l 7200 -s 7000
cmgrd on . cmgrd -b 19500 -c private -i 5
statsparser on statsmgrdir statsparser -f parserconfig.stats
statsager on statsmgrdir statsager -f parserconfig.stats
SNMPAgent on . SNMPAgent ./config/SNMPAgent.conf ./config/NOV
PortProxy on . PortProxy -v ./config/SNMPProxy.conf
ConnProxy on . ConnProxy -I ins ./config/SNMPProxy.conf
RtmProxy on . RtmProxy -v -k 2147483647
statsmain off statsmgrdir statsmain -b 19500 -display
to>:0.0
The DNS was tested and is working fine.
Regarding the file watchdog.conf? the CWM 15.3.00 is quite different: I found the file watchdog in the path /usr/users/svplus/config and has commands with syntax different that you show me (for example, ?debug level 4? as soon on). I found another file named process.conf in the path /usr/users/svplus/config and has commands very similar that you show me.
Hi Teddy,
I understand this thread is pretty old, but I'm facing the same issue today with a CWM 16.0 installation on a Solaris 9 and I was wondering if you found a solution to the problem and if you happen to remember it?
Paul
