EEM and TCL: how to delete multiple files from flash?
eseifer
I have been working on using EEM and TCL to copy multiple files (starting with file.x) from flash to an FTP server and once they have been copied, i want to delete them from flash. For example:
sho flash | i file.x
211         33 Jun 18 2011 00:36:34 file.x-01
212         33 Jun 18 2011 00:36:38 file.x-02
213         33 Jun 18 2011 00:36:40 file.x-03
214         33 Jun 18 2011 00:36:44 file.x-04
215         33 Jun 18 2011 00:36:48 file.x-05
Searching previous examples of EEM and TCL  I found the following TCL structure to copy the file via FTP:
set fileList [glob -directory flash: -nocomplain "file.x*"]
foreach file $fileList {
    if [catch {cli_exec $cli1(fd) "copy $file ftp://10.0.0.1/"} _cli_result] {
        error $_cli_result $errorInfo
This work.
However I can't seem to figure out what TCL structure to use to delete them from flash. I tried variations of the above, but they failed.
Can anyone help out?
Thank you for your help in advance!
Joe Clarke
You could simply cli_exec the "delete" command.  If you want to use pure Tcl, then add the following in the foreach loop:
if { [catch {file delete -force -- $file} result] } {
    error $result $errorInfo
Joe Clarke
That was perfect! Thanks Joe!
