Need EEM script triggered only after n syslog msg within a time frame
fmenezes
Hello.
I need to create a script for a couple of routers.
Today, when a WAN link goes down (POS1/0, and a syslog message is generated) the event-manager shuts the LAN interface G0/0 to administrative down:
event manager applet monitor-down
event syslog pattern "%LINEPROTO-5-UPDOWN: Line protocol on Interface POS1/0, changed state to down"
action 1.0 cli command "enable"
action 1.1 cli command "configure term"
action 1.2 cli command "interface Gi0/0"
action 1.4 cli command "shut"
end
This works fine but need to make it a little more refined.
What we need is a script that it is NOT triggered when there is only one occurence of the Wan-down but only if the event is repeated in subsequent 3 hours. So, the first time it happens it does nothing; at the second occurence IF this happens whitin 3 hours of the first one it does the "shut". How can this be done?
Joe Clarke
You can do this with one additional policies.  Change your first policy to this:
action 1.0 counter name wan_counter op inc value 1
Then add this one:
event manager applet wan-shutdown
event counter name wan_counter entry-op ge entry-val 3 exit-val 3 exit-op lt
action 2.0 cli command "config t"
action 3.0 cli command "int gi0/0"
action 4.0 cli command "shut"
action 5.0 cli command "end"
action 6.0 counter name wan_counter op set value 0
What these are doing is counting the syslogs.  When the count hits the threshold of 3, the Gi0/0 interface will be shutdown.
Note: the syslog event detector has the ability to count messages within a specific time window.  If you want to use that, you can get away with just one EEM policy:
event syslog pattern "%LINEPROTO-5-UPDOWN: Line protocol on Interface POS1/0, changed state to down" occurs 3 period 7200
This will look for three down messages to occur in a 2 hour window.  The time window can go as high as 4294967295 seconds.
