EEM and TCL Interface
ladius1991
Community Member
Hi.
I need help. How to implementation EEM.
I want use EEM this situation.
If the syslogmessage "Interface.., changed state to down" comes than the Router should Reload.
IOS 12.4(15)T8/T12
Sry for my bad english
Joe Clarke
This policy should work for you.
event manager applet syslog-reload
event syslog pattern "LINEPROTO-5-UPDOWN.*changed state to down"
action 1.0 reload
You may want to get a bit more specific as to which interface triggers this, though.  For example:
event syslog pattern "LINEPROTO-5-UPDOWN.*Interface GigabitEthernet0/1, changed state to down"
action 1.0 reload
Thank you
It's about Interface VLan32 and Interface VLan48
Something like this will work then.
event syslog pattern "LINEPROTO-5-UPDOWN.*Interface (Vlan32|Vlan48), changed state to down"
action 1.0 reload
