LMS 3.2 and RME NetConfig Job - No Devices
John Gooch
I'm runnig CW LMS 3.2 on Solaris 10. If I go to Resource Management Essentials, click on NetConfig, and then select "create" as in "create a NetConfig job", it takes me to the Netconfig Jobs screen. On this screen, I check  "select all devices ", but afterwards it says that "0 devices selected". There are over 1000 devices in our inventory, so I cannot understand why they are not found. They are visible on the system module, and in RME-Devices. But they are not availalble for RME Netconfig jobs.
Any ideas?
Nael Mohammad
Level 5
Level 5
What kind of netConfig job are you trying to select and device type? Provide screenshot of the issue.
When I enter the NetConfig jobs screen, I click on "create" ,which takes me to the next screen, where I click on "device" , which takes me to the next screen where I have a select "device box" and a "select task" box. Checking the "all devices" option results in "0 devices select". If I click on the "+" sign on the "all devices" option to expand a list of all devices, it changes to a "-" but does not show any devices.
About the screen shot, due to the confidential nature of my work environment, I may not be allowed to do that. I'm checking with the security manager about that now.
John Gooch
Here is the screenshot -
Try logging in as an "admin" user and try to create a netconfig job and see if the error appears. Also get me the directory listing of the following so we can see if the device packages match up.
NMSROOT\CSCOpx\MDC\tomcat\webapps\rme\WEB-INF\lib\pkgsNMSROOT\CSCOpx\www\classpath\com\cisco\nm\xms\psu\pkgs\rme
What is the amount of disk space available on the server?
