EEM applet with cli not triggering
I'm new to EEM and have this configured on 3925 router.  The intention is to remove pbr if tracking is down and add pbr if tracking is up.  When track 123 is UP, the pbr-on applet doesn't run.  When track 123 is DOWN, the pbr-off applet does run, but getting command authorization failed error with 'conf t' command.  I know there multiple errors to resolve, any assistance is greatly appreciated! Thank you...
username eemscript privilege 15 password 7 xxxxxxxx
event manager session cli username "eemscript" privilege 15
track 123 ip sla 1 reachability
ip sla auto discovery
ip sla 1
icmp-echo 12.87.191.173
ip sla schedule 1 life forever start-time now
access-list 101 permit tcp host any any eq 80
access-list 101 permit tcp host any any eq 443
access-list 101 permit tcp host any any eq 8800
route-map internet-offload permit 10
match ip address 101
set ip default next-hop 172.16.4.49
event manager applet pbr-on trap
event track 123 state up
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 3.0 cli command "interface range GigabitEthernet0/0 - 1"
action 4.0 cli command "ip policy route-map internet-offload"
action 5.0 cli command "end"
event manager applet pbr-off trap
event track 123 state down
action 4.0 cli command "no ip policy route-map internet-offload"
some displays which may assist:
usca-gwan1-rtr#sh track
Track 123
  IP SLA 1 reachability
  Reachability is Up
    1 change, last change 02:33:42
  Latest operation return code: OK
  Latest RTT (millisecs) 10
  Tracked by:
    EEM applet pbr-on
    EEM applet pbr-off
usca-gwan1-rtr#sh event manager stat policy
                                       Average        Maximum
No.  Class     Triggered   Suppressed  Run Time       Run Time       Name
1    applet    0           0           0.000          0.000          pbr-on
event {} track
2    applet    0           0           0.000          0.000          pbr-off
event {} track
usca-gwan1-rtr#sh event manager policy registered
No.  Class     Type    Event Type          Trap  Time Registered           Name
1    applet    user    track               On    Wed Sep 21 19:45:25 2016  pbr-on
track 123 state up
maxrun 20.000
2    applet    user    track               On    Wed Sep 21 19:45:38 2016  pbr-off
maxrun 20.000
Joe Clarke
Chances are your AAA config is not using the local database, so your local user doesn't matter.  You'd need to either configure "eemscript" on your AAA server or add "auth bypass" to your applet configuration line.
I see no reason that would prevent the "up" applet from running other than without valid authz, none of the actions will work.  I would check that the track is actually transitioning to an up state after fixing authz.
