EEM configuration for a TCL script dissapear from config if it is an "abort"
lmcruzmir
Friday 22...
I loaded 4 TCL scripts to the router
I configured EEM to execute the TCL scripts with kron event trigger.
Saturday 25
The EEM launched the 4 scripts...
3    3      Actv success  Sat Feb23 09:00:00 2013  timer cron         applet: 1-refresh
4    4      Actv success  Sat Feb23 09:52:00 2013  timer cron         applet: 2-refresh
5    5      Actv abort    Sat Feb23 09:55:00 2013  timer cron         applet: 3-refresh
6    6      Actv abort    Sat Feb23 09:58:00 2013  timer cron         applet: 4-refresh
The EEM code for the scripts that failed was removed by system from running-config at this time without human intervention.
Saturday 24
EEM only executes the "success" scripts becuase there is no more code for anything else:
7    7      Actv success  Sun Feb24 09:00:00 2013  timer cron         applet: 1-refresh
8    8      Actv success  Sun Feb24 09:52:00 2013  timer cron         applet: 2-refresh
Monday 25 (today)
I review the running-config:
Router#sh run | i event manager
event manager applet 1-refresh
event manager applet 2-refresh
No more applets in the running-config.
IOS with this issue is: c7200p-advipservicesk9-mz.151-4.M6.bin (it also happens in M5)
All scripts works fine with c7200p-advipservicesk9-mz.152-4.M2.bin for several days.
Re-enter the missing code in 151-4.M6 (also M5) in the running config doesn't fix the issue, it is happening again.
Is this the expected behaviour of 15.1-4M train?
18 Replies 18
Try this version to see what you get back from the HTTP session.  Each line should be printed in the logging buffer.
Here we go:
Apr 16 00:01:41 10.255.255.61 990787: 1008104: Apr 16 00:00:01.182 UTC: %HA_EM-6-LOG: tm_update_spamhaus3.tcl: XXX: Read line
Access Denied
Apr 16 00:01:41 10.255.255.61 990788: 1008105: Apr 16 00:00:01.182 UTC: %HA_EM-6-LOG: tm_update_spamhaus3.tcl: XXX: Read line
The owner of this website (www.spamhaus.org) has banned your access based on your browser's signature (957e201d-cl-ua-81). (Ref. 1010)
    Apr 16 00:01:41 10.255.255.61 990789: 1008106: Apr 16 00:00:01.182 UTC: %HA_EM-6-LOG: tm_update_spamhaus3.tcl: XXX: Read line
  • Timestamp: Mon, 15 Apr 2013 17:00:01 -0700
    Apr 16 00:01:41 10.255.255.61 990790: 1008107: Apr 16 00:00:01.182 UTC: %HA_EM-6-LOG: tm_update_spamhaus3.tcl: XXX: Read line
  • Your IP address: 149.126.32.29
  • Apr 16 00:01:41 10.255.255.61 990791: 1008108: Apr 16 00:00:01.182 UTC: %HA_EM-6-LOG: tm_update_spamhaus3.tcl: XXX: Read line
  • Requested URL: www.spamhaus.org/drop/drop.lasso
    Useragent is the problem, looks like
You can try changing the user agent by adding this code right before the ::http::geturl call:
::http::config -useragent ”Spamhaus Updater/1.0 (Cisco EEM)”
It's not clear whether that will help.  You may want to set the UA to emulate Firefox.
Changed, let's wait to the next cron cycle, for sure it works
