EEM configuration issue?
nawas
Level 4
Level 4
I'm using this EEM script to shut down a port when a cable is pulled or port goes down for any other reason. It works to shut down the port but I'm facing the following problem
1. If I attempt to re-enable the port manually it immedeately shuts it down using the EEM unless I remove the event manager configuration, re-enable the port and re-apply EEM config.
2.  I have a "wait 120"configured but it never re-enable the port after 120 seconds
Any help would be greatly appreciated.
event manager applet interface_down
event syslog pattern ".*UPDOWN.*FastEthernet0/4.* changed state to down"
action 1.0 syslog msg "Interface FastEthernet0/4 has gone down"
action 1.1 cli command "enable"
action 1.2 cli command "conf t"
action 1.3 cli command "Interface FastEthernet0/4"
action 1.4 cli command "shut"
action 1.5 cli command "end"
action 1.6  syslog msg "Interface FastEthernet0/4, changed state to administratively down"
action 1.7 wait 120
action 2.1 cli command "enable"
action 2.2 cli command "conf t"
action 2.3 cli command "Interface FastEthernet0/4"
action 2.4 cli command "no shut"
action 2.5 cli command "end"
15 Replies 15
What does your logging trap config look like?  EEM syslogs are sent using the debugging routine, so you need to make sure you have "logging trap debug" configured.
