EEM Email Script Not Working
Hello Support,
I have created the following script to send me an email when the cpu is high on our router:
event manager applet high_cpu
event snmp oid 1.3.6.1.4.1.9.9.109.1.1.1.1.3.1 get-type exact entry-op gt entry-val "5" poll-interval 60
action 1.01 syslog msg "------HIGH CPU DETECTED----, CPU: $_snmp_oid_val %"
action 1.02 info type routername
action 1.03 syslog msg "$msg"
action 1.04 mail server "10.45.1.40" to "carlton.patterson@skanska.co.uk" from "carlton@keyloop.co.uk" subject "$_info_routername" body "$msg"
Everything is working well apart from the body of the script.
I keep on getting the following error message:
Mar  7 16:50:27.976: %HA_EM-6-LOG: high_cpu: ------HIGH CPU DETECTED----, CPU: 24 %
Mar  7 16:50:27.976: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: msg
Mar  7 16:50:27.976: %HA_EM-3-FMPD_ERROR: Error executing applet high_cpu statement 1.03
I'm quite sure its something simple that I'm missing but I can't see it.
Any help will be greatly appreciated
Cheers
Carlton
6 Replies 6
Joe Clarke
You never define $msg anywhere.  You need to use the "set" action to set this vairable to some value (i.e., the message you want to send).
Thanks Joseph
Cheers
Hello
I have created the following script  Any change to the config will be immediatly reported to me via an msg
event manager applet configuration_change_manuell
event syslog pattern “.*%SYS-5-CONFIG_I.*”
action 1.1 cli command “enable”
action 1.2 cli command “show archive log config all”
action 1.3 syslog msg "Config has been changed"
But I have a problem:
R2#
*Apr 15 11:38:26.947: %SYS-5-CONFIG_I: Configured from console by console
*Apr 15 11:38:27.031: %PARSER-5-CFGLOG_LOGGEDCMD: User:unknown user  logged command:!exec: enable
R2#
*Apr 15 11:38:27.151: %HA_EM-6-LOG: configuration_change_manuell: Config has been changed
the msg is posted but the command"show archive log config all" has not market and I get an error
"User:unknown user  logged command:!exec: enable"
Please start a new thread for your issue.
I get an error with this script "User:unknown user  logged command:!exec: enable"
what I have to do???
Please start a new top-level thread for this idea.  Do not post into an existing thread as it confuses things for new users.
