EEM issue
ecritel75
Dear,
I am trying to configure an EEM applet  in order to shut an interface when an ip sla failed. On this router we use AAA so i have configured an aaa  list to bypass authorization .
aaa authentication login EEM none
aaa authorization config-commands
aaa authorization exec default if-authenticated
aaa authorization exec EEM none
aaa authorization commands 0 EEM none
aaa authorization commands 1 EEM none
aaa authorization commands 15 EEM none
And i use a dedicated line to execute this applet :
line vty 0
login authentication EEM
transport input none
My applet configuration is :
event manager applet SHUTDOWN_LO1
event track 10 state down
action 1.0 syslog msg "Timeout to reach 10.100.1.1"
action 1.1 cli command "enable"
action 1.2 cli command "configure terminal"
action 1.3 cli command "interface loopback1"
action 1.4 cli command "shutdown"
My issue is when this applet is executed, it block on the "configure terminal" action :
Jul 26 11:50:33.198: fh_server: fh_io_msg: received msg FH_MSG_EVENT_REQINFO from client 36 pclient 1
Jul 26 11:50:33.198: %HA_EM-6-LOG: SHUTDOWN_LO1: Timeout to reach 10.100.1.1
Jul 26 11:50:33.198: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : CTL : cli_open called.
Jul 26 11:50:33.242: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : OUT :
Jul 26 11:50:33.242: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : OUT : ROUTER>
Jul 26 11:50:33.242: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : IN  :ROUTER>enable
Jul 26 11:50:33.246: cli_history_entry_add: free_hist_list size=0, hist_list size=7
Jul 26 11:50:33.246: eem_no_scan flag set, skipping scan of command_string=check_eem_cli_policy_handler
Jul 26 11:50:33.254: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : OUT :
Jul 26 11:50:33.254: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : OUT :ROUTER#
Jul 26 11:50:33.254: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : IN  : ROUTER#configure terminal
Jul 26 11:50:33.258: cli_history_entry_add: free_hist_list size=0, hist_list size=7
And then i saw that the line vty 0 is used but stuck in idel state
ROUTER#systat
    Line       User       Host(s)              Idle       Location
194 vty 0                idle                 00:00:46
And on the next execution , i saw that the router try to execute next steps on the previous call for this applet
Jul 26 11:55:18.170: %HA_EM-6-LOG: SHUTDOWN_LO1: Timeout to reach 88.191.97.16
Jul 26 11:55:18.170: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : CTL : cli_open called.
Jul 26 11:55:18.254: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : OUT :
Jul 26 11:55:18.254: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : OUT : ROUTER>
Jul 26 11:55:18.254: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : IN  : ROUTER>enable
Jul 26 11:55:18.254: cli_history_entry_add: free_hist_list size=0, hist_list size=7
Jul 26 11:55:18.254: eem_no_scan flag set, skipping scan of command_string=check_eem_cli_policy_handler
Jul 26 11:55:18.266: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : OUT :
Jul 26 11:55:18.266: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : OUT : ROUTER#
Jul 26 11:55:18.266: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : IN  : ROUTER#configure terminal
Jul 26 11:55:18.482: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : OUT : Command authorization failed.
Jul 26 11:55:18.482: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : OUT :                       ^
Jul 26 11:55:18.482: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : OUT : % Invalid input detected at '^' marker.
Jul 26 11:55:18.482: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : OUT : ROUTER#
Jul 26 11:55:18.482: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : IN  : ROUTER#interface loopback1
Jul 26 11:55:18.498: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : OUT :                        ^
Jul 26 11:55:18.498: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : OUT : % Invalid input detected at '^' marker.
Jul 26 11:55:18.498: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : OUT : ROUTER#
Jul 26 11:55:18.498: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : IN  : ROUTER#shutdown
Jul 26 11:55:18.814: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : OUT : Command authorization failed.
Jul 26 11:55:18.814: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : OUT :                         ^
Jul 26 11:55:18.814: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : OUT : % Invalid input detected at '^' marker.
Jul 26 11:55:18.814: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : OUT : ROUTER#
Jul 26 11:55:18.814: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : IN  : ROUTER#exit
Jul 26 11:55:18.814: %HA_EM-6-LOG: SHUTDOWN_LO1 : DEBUG(cli_lib) : : CTL : cli_close called.
Thanks for any help.
Okay, it's the version problem.  You're seeing CSCsz70112.  You need to upgrade to an EEM 2.3 image (12.4(11)T or higher).  You should consider something a bit newer, though.  A 15.x mainline image would be better.
Joe Clarke
What version of code is this, and what is the actual ROUTER prompt?  We have had a number of bugs with prompts and switching CLI modes.
Hi Joseph,
The device in question is a Cisco router 1841 with
c1841-adventerprisek9-mz.124-9.T1.bin IOS firmware.
Regarding EEM version, i think the current version is a 2.2 because i can track an event but i have only an action of cli type and not pattern.
The actual prompt for this device is enable mode.
ROUTER#
Hi Clarke,
Thanks for this update, i will update this device quickly.
Regards.
