11-17-2011 06:15 AM
Hello all,
I am trying to configure an EEM which shutdown and interface when the track is down but i remark that the action of EEM not start despite that every seem good. Here is the config :
ip sla 5
icmp-echo 8.8.8.8
timeout 20000
threshold 15000
frequency 25
ip sla schedule 5 life forever start-time now
track 1 ip sla 5
event manager applet SET-DOWN-INTERFACE
event track 1 state down
action 1.0 cli command "enable"
action 1.1 cli command "conf t"
action 1.2 cli command "int fastethernet 0/0"
action 1.3 cli command "shutdown"
action 1.4 cli command "end"
action 1.5 cli command "exit"
SHow command :
#sh ip sla statisti
IPSLA operation id: 5
Type of operation: icmp-echo
Latest RTT: NoConnection/Busy/Timeout
Latest operation start time: *14:07:36.962 UTC Thu Nov 17 2011
Latest operation return code: Timeout
Number of successes: 0
Number of failures: 6
Operation time to live: Forever
#sh track brief
Track Object Parameter Value Last Change
1 ip sla 5 state Down 01:09:39
Despite the fact that everything is down, EEM does not execute. Who can help me ?
Thanks in advance.
Solved! Go to Solution.
11-18-2011 08:26 AM
Is the tracked object changing state? That is, are you able to get the object to transition to up then down again? That needs to happen for the applet to execute. From your IP SLA show command output, it does not appear the collector is ever succeeding.
11-17-2011 08:44 AM
Enable "debug event manager action cli" then bounce the tracked object to get the policy to run again. What debugging output do you see?
11-18-2011 12:58 AM
Hi Clarke,
The debug event manager action cli send nothing.
I do also debug event manager all. I just have this periodly :
001294: *Nov 18 08:58:00.002 UTC: fh_fd_timer_process_async
001295: *Nov 18 08:58:00.002 UTC: cron_tick: num_matches 0
It's seem that it was unable to receive the result of the track to trigger actions.
I do :
debug event manager detector cli
debug event manager detector track
debug event manager detector ipsla
But nothing.
11-18-2011 08:26 AM
11-19-2011 05:36 AM
Is your track configured for reachability or state ??
Smitesh
11-22-2011 02:55 AM
Hi Joseph,
Yes it's becausethe tracked object doesn't changing. I do the test with tracked changing and it's okay.
Thanks all.
12-16-2011 02:42 AM
Hi Smitesh,
How can I configure the eem to checked state of two track before performing an action.
the State of the two track must be down or UP for example that it execute action
If i take my config above :
ip sla 5
icmp-echo 8.8.8.8
timeout 20000
threshold 15000
frequency 25
ip sla 5
icmp-echo 8.8.8.8
timeout 20000
threshold 15000
frequency 25
ip sla 10
icmp-echo 4.4.4.4
timeout 20000
threshold 15000
frequency 25
track 1 ip sla 5
track 2 ip sla 10
How configure the event manager to doconfigure an interface only when the state of this two track is down or UP
Best Regards
12-16-2011 07:13 PM
You can do one of two things. You can either create a boolean tracked object or use multiple event detectors. For example, to use a boolean tracked object, do:
track 3 list boolean and
object 1
object 2
Then you can track object 3 with your EEM policy.
