EEM On Nexus 7K Question
Hello Community,
Can someone please tell me why I can't create the following on Nexus 7K:
event manager directory user policy "flash:/
I only have the following options:
MX-N7K2-AGG2(config)# event manager ?
  applet       Create/Modify an Event Manager Policy
  environment  Configure an environment variable
  policy       Register a script policy and activate it Enter configuration commands, one per line.  End with CNTL/Z.
Cheers
Carlton
Tcl is from manually run scripts.  Tcl and EEM is not officially supported, and there is no functionality for native EEM Tcl policies.
9 Replies 9
mtimm
The EEM feature on NX-OS is totally different from the EEM feature on IOS.  They share the same spirit but not the same code base.
Mike
Mike, thanks for responding.
I understand the IOS is different, however I thought there might be an equivalent command?
There is none.  You can register a script, but only a VSH script.  Tcl policies are not supported on NX-OS.
Hi Joseph, thanks for responding.
I remember asking on this forum if Tcl was supported on NX-OS and I was told it was supported on Nexus 7K but not on Nexus 5k ......
That is a shame.
Joseph, are there any tools used to troubleshoot Nexus that you would recommend?
You might want to ask this on one of the Data Center or Switching forums.  I don't do much general troubleshooting of Nexus issues.
Ok, thanks
