Numeric process names in PDSHOW
jedavis
Level 4
Level 4
I have numeric process names showing up under Admin => Server Monitoring => Processes.  The list seems to keep growing.  What are these? Here is a pdshow -brief
  Process               State                                     Pid
  UPMDbEngine           Program started - No mgt msgs received    19812
  UPMDbMonitor          Running normally                          23404
  Tomcat                Program started - No mgt msgs received    22624
  TomcatMonitor         Running normally                          21440
  Apache                Program started - No mgt msgs received    23640
  TopoServer            Program started - No mgt msgs received    15836
  RMEDbEngine           Program started - No mgt msgs received    16212
  Proxy                 Program started - No mgt msgs received    15428
  NameServer            Program started - No mgt msgs received    15436
  NameServiceMonitor    Program started - No mgt msgs received    23680
  EDS                   Running normally                          15336
  LicenseServer         Program started - No mgt msgs received    16060
  IpmDbEngine           Program started - No mgt msgs received    16068
  INVDbEngine           Program started - No mgt msgs received    13428
  FHPurgeTask           Never started                             0
  FHDbEngine            Program started - No mgt msgs received    14976
  ESS                   Program started - No mgt msgs received    23240
  EssMonitor            Running normally                          14008
  EventFramework        Program started - No mgt msgs received    14376
  PMServer              Running normally                          14696
  SyslogCollector       Running normally                          14684
  EPMDbEngine           Program started - No mgt msgs received    14728
  EPMServer             Running normally                          14068
  FHServer              Running normally                          13628
  diskWatcher           Running normally                          13636
  DFMMultiProcLogger    Program started - No mgt msgs received    13644
  DFMLogServer          Program started - No mgt msgs received    13652
  DFMCTMStartup         Administrator has shut down this server   0
  DfmBroker             Running normally                          13688
  DfmServer             Program started - No mgt msgs received    16556
  DfmServer1            Running normally                          16572
  DCRDevicePoll         Never started                             0
  CSSCPServer           Program started - No mgt msgs received    16584
  CSRegistryServer      Running normally                          16596
  CSDiscovery           Never started                             0
  CmfDbEngine           Program started - No mgt msgs received    16612
  CmfDbMonitor          Running normally                          12140
  DCRServer             Running normally                          22216
  CMFOGSServer          Program started - No mgt msgs received    20388
  EssentialsDM          Running normally                          21124
  CAAMServer            Running normally                          19448
  ConfigMgmtServer      Running normally                          19340
  ConfigUtilityService  Running normally                          11348
  ICServer              Running normally                          11360
  EnergyWise            Running normally                          11544
  PMCOGSServer          Program started - No mgt msgs received    12668
  IPMOGSServer          Program started - No mgt msgs received    13860
  TISServer             Program started - No mgt msgs received    10556
  DFMOGSServer          Program started - No mgt msgs received    19820
  InventoryCollector    Running normally                          18968
  Interactor            Program started - No mgt msgs received    9544
  InventoryCollector1   Program started - No mgt msgs received    9552
  Interactor1           Program started - No mgt msgs received    17432
  NOSServer             Running normally                          11920
  PTMServer             Running normally                          11928
  UPMProcess            Running normally                          11824
  EDS-GCF               Running normally                          11812
  jrm                   Running normally                          11816
  1018                  Never started                             0
  3610                  Never started                             0
  3700                  Never started                             0
  3737                  Never started                             0
  4113                  Never started                             0
  4211                  Never started                             0
  4212                  Never started                             0
  4213                  Never started                             0
  4216                  Never started                             0
  4240                  Never started                             0
  4244                  Never started                             0
  4326                  Never started                             0
  4328                  Never started                             0
  4330                  Never started                             0
  4332                  Never started                             0
  4333                  Never started                             0
  4380                  Never started                             0
  4383                  Never started                             0
  4385                  Never started                             0
  4389                  Never started                             0
  4391                  Never started                             0
  4883                  Never started                             0
  4884                  Never started                             0
  4888                  Never started                             0
  4891                  Never started                             0
  4893                  Never started                             0
  4899                  Never started                             0
  4900                  Never started                             0
  4967                  Never started                             0
  4968                  Never started                             0
  4969                  Never started                             0
  4970                  Never started                             0
  5206                  Never started                             0
  5207                  Never started                             0
  5208                  Never started                             0
  5211                  Never started                             0
  5212                  Never started                             0
  5213                  Never started                             0
  5214                  Never started                             0
  5215                  Never started                             0
  5216                  Never started                             0
  5217                  Never started                             0
  5218                  Never started                             0
  5219                  Never started                             0
  5220                  Never started                             0
  5221                  Never started                             0
  5222                  Never started                             0
  5223                  Never started                             0
  5230                  Never started                             0
  5232                  Never started                             0
  5233                  Never started                             0
  5234                  Never started                             0
  5897                  Never started                             0
  5898                  Never started                             0
  5913                  Never started                             0
  5914                  Never started                             0
  5925                  Never started                             0
  6094                  Never started                             0
  CTMJrmServer          Running normally                          8996
  ChangeAudit           Program started - No mgt msgs received    8288
  SyslogAnalyzer        Running normally                          8296
  DataPurge             Administrator has shut down this server   0
  IPMProcess            Program started - No mgt msgs received    8312
  ANIDbEngine           Program started - No mgt msgs received    8516
  ANIServer             Running with busy flag set                7528
  UTMajorAcquisition    Program started - No mgt msgs received    1868
  MACUHIC               Running normally                          7220
  UTLITE                Running normally                          7196
  UTManager             Running normally                          7236
  VNMServer             Program started - No mgt msgs received    15200
  WlseUHIC              Running normally                          17304
  AdapterServer1        Program started - No mgt msgs received    23908
  AdapterServer         Program started - No mgt msgs received    17364
And picking a random process, a "pdcmd -l 4888":
        Process      = 4888
        Path         = d:\software\CSCOpx\bin\cwjava.exe
        Flags        = -cw:jre lib/jre -cp d:\software\CSCOpx\MDC\tomcat\shared\lib\MICE.jar,d:\software\CSCOpx\MDC\tomcat\shared\lib\NATIVE.jar,d:\software\CSCOpx\MDC\tomcat\shared\lib\jdom.jar,d:\software\CSCOpx\MDC\tomcat\shared\lib\xalan.jar,d:\software\CSCOpx\MDC\tomcat\shared\lib\xerces.jar,d:\software\CSCOpx\MDC
\tomcat\common\lib\servlet.jar,d:\software\CSCOpx\MDC\tomcat\shared\lib\castor-0.9.5.jar,d:\software\CSCOpx\MDC\tomcat\shared\lib\castor-0.9.5-xml.jar,d:\software\CSCOpx\lib\classpath,d:\software\CSCOpx\www\classpath,www\classpath\vbjorb.jar,MDC/tomcat/webapps/rme/WEB-INF/classes,MDC/tomcat/webapps/rme/WEB-INF/lib/log4j.jar,MDC/tomcat/webapps/rme/WEB-INF/lib/ags.jar,MDC/tomcat/webapps/rme/WEB-INF/lib/xdi.jar,MDC/tomcat/webapps/rme/WEB-INF/lib/ctm.jar,MDC/tomcat/common/lib/servlet.jar,MDC/tomcat/common/lib/activation.jar,MDC/tomcat/webapps/rme/WEB-INF/lib/deviceselector.jar,MDC/tomcat/webapps/rme/WEB-INF/lib/cogs.jar,MDC/tomcat/webapps/rme/WEB-INF/lib/ogs-client.jar,MDC/tomcat/webapps/rme/WEB-INF/lib/ogs-util.jar,MDC/tomcat/webapps/rme/WEB-INF/lib/uii.jar,MDC/tomcat/webapps/cwhp/WEB-INF/lib/iText.jar,MDC/tomcat/webapps/cwhp/WEB-INF/lib/struts.jar,MDC/tomcat/shared/lib/MICE.jar,MDC/tomcat/shared/lib/NATIVE.jar -Xms128m -Xmx512m -Dnm.jrm.jobid=4888
com.cisco.nm.rmeng.inventory.cda.job.CDAJobRunner
        Startup      = Started by operator command.
        Dependencies = jrm
TIA,
-Jeff
Duong Nguyen
bump
