EEM: "event routing network" vrf aware?
rokraus
Hello everybody!
I've 2 questions related to above topic:
1.) how do I get the vrf information for a route beeing changed.
2.) how do I track all routes in the routing table. including default-route
The following command: event routing network 0.0.0.0/0 ge 1;  does not match the default-route.
Complete applet:
event manager applet route-table-monitor
action 1.0 syslog msg "Route changed: Type: $_routing_type, Network: $_routing_network, Mask/Prefix: $_routing_mask, Protocol: $_routing_protocol, GW: $_routing_lastgateway, Intf: $_routing_lastinterface"
As a workaround for the above: (This monitors all routes inclouding default-route; however there is still no vrf info)
event tag e1 routing network 0.0.0.0/0
event tag e2 routing network 0.0.0.0/0 ge 1
trigger occurs 1
  correlate event e1 or event e2
Best regards
Robert
Joe Clarke
Your workaround for the default route is correct.  You have to watch the 0.0.0.0 route, and you can't have the ge value be 0 :-(.
For VRF, this was added in EEM 4.0.  There is now a "vrf" keyword for the routing ED.
Hi Joseph!
Thx for your reply. I found the same fot the VRF thing and changed the applet to:
event tag e1 routing network 0.0.0.0/0 ge 1 vrf name mandant1 maxrun 2
event tag e2 routing network 0.0.0.0/0 ge 1 vrf name mandant1
trigger occurs 1
action 1.0 syslog msg "Route changed: Type: $_routing_type, VRF: $_routing_vrf_name, $_routing_protocol, $_routing_network/$_routing_mask [$_routing_distance/$_routing_metric] via $_routing_lastgateway, $_routing_lastinterface"
Unfrotunately, almost all of our devices do not support eem 4.0
Once again thank's a lot.
