rmeng Database connection error
thongams2000
Community Member
I've got an error message here while trying to open the rmeng database -
*** Error ***
Could not connect to database: Database server not found (DBD: login failed)
I am using LMS 3.2 , RME 4.3. Need help on troubleshooting the error.
10 Replies 10
thongams2000
Community Member
pdshow output :
Process               State                                     Pid
UPMDbEngine           Program started - No mgt msgs received    10836
UPMDbMonitor          Running normally                          2908
Tomcat                Program started - No mgt msgs received    3884
TomcatMonitor         Running normally                          9952
Apache                Program started - No mgt msgs received    632
RMEDbEngine           Program started - No mgt msgs received    4720
Proxy                 Program started - No mgt msgs received    3480
ProcSysBus            Program started - No mgt msgs received    6396
OpsxmlDbEngine        Program started - No mgt msgs received    10084
OpsXMLRuntime         Program started - No mgt msgs received    6612
CWAPublisher          Administrator has shut down this server   0
NameServer            Program started - No mgt msgs received    12144
NameServiceMonitor    Running normally                          8768
EDS                   Running normally                          5692
LicenseServer         Program started - No mgt msgs received    9444
ESS                   Program started - No mgt msgs received    11288
EssMonitor            Running normally                          9588
EventFramework        Program started - No mgt msgs received    6044
SyslogCollector       Program started - No mgt msgs received    4912
diskWatcher           Running normally                          5260
DCRDevicePoll         Never started                             0
CSSCPServer           Program started - No mgt msgs received    6220
CSRegistryServer      Running normally                          10716
CSDiscovery           Never started                             0
CmfDbEngine           Program started - No mgt msgs received    7404
CmfDbMonitor          Running normally                          11192
DCRServer             Running normally                          7708
CMFOGSServer          Program started - No mgt msgs received    10960
EssentialsDM          Waiting to initialize.                    7104
ConfigMgmtServer      Administrator has shut down this server   0
ICServer              Administrator has shut down this server   0
RMEOGSServer          Administrator has shut down this server   0
PMCOGSServer          Administrator has shut down this server   0
UPMProcess            Running normally                          6136
EDS-GCF               Running normally                          11912
jrm                   Running normally                          10940
1008                  Never started                             0
2227                  Never started                             0
2228                  Never started                             0
2623                  Never started                             0
2640                  Never started                             0
2647                  Never started                             0
2648                  Never started                             0
2765                  Never started                             0
2971                  Never started                             0
3210                  Never started                             0
3459                  Never started                             0
3844                  Never started                             0
3845                  Never started                             0
3965                  Never started                             0
4412                  Never started                             0
4644                  Never started                             0
4913                  Never started                             0
4915                  Never started                             0
4920                  Never started                             0
4951                  Never started                             0
4961                  Never started                             0
4968                  Never started                             0
4973                  Never started                             0
4998                  Never started                             0
4999                  Never started                             0
5023                  Never started                             0
5024                  Never started                             0
5040                  Never started                             0
5056                  Never started                             0
5057                  Never started                             0
5074                  Never started                             0
5092                  Never started                             0
5116                  Never started                             0
5140                  Never started                             0
5159                  Never started                             0
CTMJrmServer          Administrator has shut down this server   0
ChangeAudit           Administrator has shut down this server   0
SyslogAnalyzer        Administrator has shut down this server   0
2596                  Program started - No mgt msgs received    7064
Not sure what you are trying , when you say trying to open RME DB. Are you trying to connect to RME DB via ODBC?
Please confirm or if this error is seen somwhere esle?
I would like to suggest you as first thing to upgrade to LMS 3.2.1 once this issue is resolved?
Are you on win/sol? I see you processes down as :
If you have a windows machine and you have Windows Remote Management service running, it may be an issue as it takes the same port some RME services need.
You can try to disbale it and restart Deamon manager, it should work. if that service needs to run, you have to follow this procedure :
> shutdown the daemon Manager (net stop ccrmdmgtd)
> remove ctmregistry* from NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/lib
> start the daemon Manager (net start crmdmgtd)
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Hi Vinod,
Thanks for the reply..
I am trying to login the rmeng database using -
https://MYSERVER/dbreader/dbreader.html
I have a windows 2008 server and I access it using RDP. It would be very helpful if you can tell me how to check the
Windows Remote Management service ports and the RME service ports.
Basically the issue is with RME Database. The RMEDbEngine is shutting down automatically very frequently and due to which other dependent proccesses also showing shut down in the above output. I found that the size of Syslog databases - SyslogSecond.db, SyslogThird.db are very big and consuming a lot of space. So I was finding a way to check the database tables.
Regards.
Basically ports acquired by processes can be seen by any free utility like cports or currports. They display the list of all currently opened TCP/IP and UDP ports on your local computer.
However that is not important. If you simply follow the process mentioned above of deleting ctmregistry* files from directory and restart daemon manager it should be fine.
Than you can check pdshow -brief to see all processes come up.
For syslog.db issue you may have to delete many tables from DB access. We usually dont recommend to access DB and do anything with that.
However there are other mechanisms where you could try to perform the following Administrative tasks:
•Back up Syslog messages (see Setting the Backup Policy).
•Purge Syslog messages (see Setting the Purge Policy).
•Perform a Forced Purge (see Performing a Forced Purge).
However if purging all data from syslog is an option, and start all over for syslog only, you can use the following perl utility to purge all syslog data from syslog*.db and reclaim space with default size.
NMSROOTMDC\tomcat\webapps\rme\WEB-INF\debugtools\dbcleanup\DBSpaceReclaimer.pl.
-Thanks
I tried deleting ctmregistry* files following the same procedure as given by you but the RMEDbEngine shuts down again after sometime and now I can see the following three files again in the NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/lib
ctmregistry
ctmregistry.backup
ctmregistry_1359642613752_0.40037950228351094
I am also not able to run a force purge, getting the following error message  :
SLCA0117: Syslog Force purge Job Creation Failed. Check the log for details.
Regards.
Please share the latest pdshow -brief from server and try pdexec EssentialsDM and share EssentialsDM.log.
-thanks
I think the EssentialsDM is down because the RMEDbEngine went down. I tried restarting both. It will run for sometime and then shuts off again automatically.
pdshow -brief output before the proccess restart :
Process               State                                     Pid
UPMDbEngine           Program started - No mgt msgs received    3836
UPMDbMonitor          Running normally                          6248
Tomcat                Program started - No mgt msgs received    6324
TomcatMonitor         Running normally                          5852
Apache                Program started - No mgt msgs received    6024
RMEDbEngine           Administrator has shut down this server   0
Proxy                 Program started - No mgt msgs received    10088
ProcSysBus            Program started - No mgt msgs received    4084
OpsxmlDbEngine        Program started - No mgt msgs received    9856
OpsXMLRuntime         Program started - No mgt msgs received    2308
NameServer            Program started - No mgt msgs received    10268
NameServiceMonitor    Running normally                          11632
EDS                   Running normally                          10108
LicenseServer         Program started - No mgt msgs received    6608
ESS                   Program started - No mgt msgs received    7724
EssMonitor            Running normally                          7556
EventFramework        Program started - No mgt msgs received    2784
SyslogCollector       Program started - No mgt msgs received    11036
diskWatcher           Running normally                          11524
CSSCPServer           Program started - No mgt msgs received    948
CSRegistryServer      Running normally                          6996
CmfDbEngine           Program started - No mgt msgs received    10992
CmfDbMonitor          Running normally                          7092
DCRServer             Running normally                          1224
CMFOGSServer          Program started - No mgt msgs received    11740
EssentialsDM          Administrator has shut down this server   0
UPMProcess            Running normally                          12276
EDS-GCF               Running normally                          10260
jrm                   Running normally                          4148
2596                  Program started - No mgt msgs received    8596
There are a lot of DB related errors which would need various logs to be collected and troubleshooting involving LMS engineering team.
I would recommedn to open a TAC case.
if you are not worried about the data lost from RME Db, you can try to re-initialize the RME DB which, in one issue, i remember fixed the problem, in similar errors we see here.
-Thanks
Procedure for DB reinitialise and commands :
https://supportforums.cisco.com/docs/DOC-8796
-Thanks
