EEM - random delay / wait
how can i delay an actions in a applet? But it should no be a fixed time, the best solution would be a random value. Let's say +/- 5s...
If generating a real random a valus is not possible, some pseudo-random value might help. Something like extracting a numeric value from the router's serial#.
thanks for ideas / Karsten
Jason Pfeifer
While not necessarily random you could use the msec parameter of show clock output to simulate a random number between 0 and 5 using something like this:
event manager applet two
event none
action 1   cli command "show clock"
action 2   regexp ".*\.([0-9]+).*" "$_cli_result" match msec
action 2.5 divide $msec 6
action 3   puts "random: $_remainder"
Unfortunately the wait action does not accept a variable name as input so if you wanted to run commands in a loop and have each one run at a random second you would have to create a wait loop prior to running the command.  Here is an example:
event manager applet three
event none maxrun 60
action 098 puts "loop running 5 times"
action 099 set count 0
action 100 while $count lt 5
action 101  cli command "show clock"
action 102  regexp ".*\.([0-9]+).*" "$_cli_result" match msec
action 102.6 multiply $count $count
action 102.7 multiply $msec $_result
action 103  divide $_result 6
action 104  set i "0"
action 105  while $i le $_remainder
action 106   wait 1
action 107   incr i
action 108  end
action 109  puts "waited $_remainder seconds"
action 110  incr count
action 111 end
action 112 puts "loop finished"
This will produce output such as:
#ev man run three
waited 0 seconds
waited 5 seconds
waited 2 seconds
waited 3 seconds
waited 2 seconds
loop finished
Jason Pfeifer
event none
action 106   wait 1
action 107   incr i
action 108  end
action 111 end
#ev man run three
waited 0 seconds
waited 5 seconds
waited 2 seconds
waited 3 seconds
waited 2 seconds
loop finished
Hello Jason,
thanks a lot for the great explanation!
Your script shows me the right way. But i have to modify something. Let me explain, i've got >100 routers with the same ntp-syncronized clock. And i want to avoid the action to be happen at same time, that's the reason why i am looking for randomizing it. So the clock might be not optimal.
Any idea, what could be a different value from router to router? Serial# was my first idea. Something else?
thanks / Karsten
