eem regexp multiple variables
markrobinson
Visitor
I need some regexp help in EEM
I'm trying to extract the IP and the Metric out of a show ip route statement
example of show ip route:
E    192.172.0.0 [200/3565] via 131.119.254.244, 0:02:22, Ethernet2
Would like to extract 192.172.0.0 to a variable as well as the metric 3565 into a different variable.
I have this statement that correctly pulls the IP
foreach line "_cli_result" "\n"
regexp "([0-9]+\.[0-9]+\.[0-9]+\.[0-9]+)" "$line" IP
puts "$IP"
What regex can i add to the statement to also pull the "3565" into a variable called "metric"
I tried so many combinations from searching the forums and I keep getting a null result so nothing is printed from the puts
Thank you
 The first variable is the Matchvar followed by subvar that are captured by paren().  The first set of paren is the first sub var, second set of parent is second subvar, etc..
Try this policy.
event manager applet showiprouteMetric
 event none
 action 010 cli command "enable"
 action 020 cli command "term length 0"
 action 030 cli command "show ip route ospf"
 action 040 foreach line "$_cli_result" "\n"
 action 050  regexp "([0-9]+\.[0-9]+\.[0-9]+\.[0-9]+)/[0-9]+ \[[0-9]+/([0-9]+)\]" "$line" match IP metric
 action 060  if $_regexp_result eq "1"
 action 070   puts "$IP and $metric"
 action 080  end
 action 090 end
8 Replies 8
action 3.0 regexp "\\[[0-9]+/([0-9]+)\\]" "$_cli_result" metric <<- try this
MHM
Thanks for the super fast reply
action 3.0 regexp "\\[[0-9]+/([0-9]+)\\]" "$_cli_result" metric  This command returns both the distance and metric values
"[200/3565]"
 I need to only get the "3565"
can I see how you config puts ?
MHM
Sure,  I apologize if there are any typos.  I do not have access to the router from any internet facing computer so have to hand type the configs.
**this applet returns the [AD/Metric] for all routes in the routing table.  including the brackets.  I can say that the AD will remain a constant number if that is easier to make an expression for.  [200/(metric)]
event none
action 1.1 cli command "enable"
action 1.2 cli command "term length 0"
action 1.3 cli command "show ip route ospf"
action 2.0 foreach line "$_cli_result" "\n"
action 2.0.1 regexp "\\[[0-9]+/([0-9]+)\\]" "$line" metric
action 2.0.2 if $_regexp_result eq "1"
action 2.0.3 puts "$metric"
action 2.1 end
action 2.2 end
event manager applet showiprouteMetric_Workaround_05
event none
action 2.0 regexp "\\[[0-9]+/[0-9]+\\]" "$_cli_result" bracket
action 2.1 if $_regexp_result eq "1"
action 2.2 regexp "/([0-9]+)" "$bracket" metric
action 2.3 puts "Extracted OSPF metric: $metric"
action 2.4 end
action 3.0 if $_regexp_result ne "1"
action 3.1 puts "No metric matched"
action 3.2 end
after long  try I get this check it
the result will be
Extracted OSPF metric: /2
Try this policy.
 event none
 action 080  end
 action 090 end
Thank you sir!
Your explanation of the parent and sub var is what I was missing.  I was able to change you regexp to also pull the subnet mask also as a test.
One question.  do you only use "match" in the regexp statement when matching more than one expression?
The match variable can be any variable name that you assign to the regexp.
