EEM Script for Syslog - Catalyst 3750 Switch
AngeloVitalone1
trying to figure out how to generate an eem email from a cisco 3750g switch when
the switch receives a warning state syslog message from a BPDUGuard event:
#1
I have tried the folliowing three configs without success
no event manager applet BPDUGUARD_TEST
  event syslog occurs 1 pattern "BPDUGUARD" period 1
  action 100 regexp "BPDUGUARD" "$_syslog_msg" ifname
  action 210 cli command "sh log | i SPANTREE-2-BLOCK_BPDUGUARD"
  action 230 regexp "Description: (.*)
" "$_cli_result" desc
  action 240 syslog msg "$desc"
  action 250 mail server "$smtphost" to "$email_to" from "eem@$_info_routername" subject "Error Disable Notification @ $_info_routername" body "$_cli_result"
#2
BPDUGUARD_TEST
   action 1.0 info type routername
   action 1.1 regexp "BPDUGUARD" "$_syslog_msg" ifname
   action 2.1 cli command "sh log | i SPANTREE-2-BLOCK_BPDUGUARD"
   action 2.2 regexp "Description: (.*)
   action 2.3 syslog msg "$desc"
   action 2.4 mail server "$smtphost" to "$email_to" from "eem@$_info_routername" subject "Error Disable Notification @ $_info_routername" body "$_cli_result"
   action 3.0 cli command "clear archive log config force"
#3
event manager applet BPDUGUARD_EVENT
   event syslog pattern "%SPANTREE-2-BLOCK_BPDUGUARD:"
   action 1.0 syslog priority warnings msg "BPDUGUARD Spanning-Tree Event"
   action 2.0 mail server "$smtphost" to "$email_to" from "eem@$_info_routername" subject "BPDUGuard Spanning-Tree Event @ $_info_routername"
6 Replies 6
Joe Clarke
All should work, though your regexp should look like:
action 230 regexp "Description: (.*)" "$_cli_result" match desc
Chances are your SMTP server is not accepting email from your device.  You can enable "debug event manager action mail" to see what it's returning.
thank you for responding to this question
I did really try to hammer this one out
and I did switch gears a tad but made progress
The following script actually emails our group but we only receive the following via email:
% Invalid input detected at '^' marker
New Configuration
event manager applet SYSLOG_BPDUGUARD_EVENT
event syslog pattern ".*%SPANTREE-2-BLOCK_BPDUGUARD*."
action 100 info type routername
action 210 cli command "enable"
action 230 cli command "show archive log SPANTREE all"
action 250 mail server "$smtphost" to "$email_to" from "eem@$_info_routername" subject "BPDUGuard Event @ $_info_routername" body "$_cli_result"
action 260 cli command "clear archive log config force"
What happens when you run these commands manually:
enable
Do you have AAA command authorization configured?
no on the AAA auth
I ran the commands independantly and it shows invalid input detected
are you aware of a way to pull only the BPDUGuard information (including hostname and port number involved) into an email??
I have this config and script loaded to email our group when an admin enters into global config mode and/or makes a config change and this works perfectly so I used it as a baseline config
event manager environment email_to alert4@lipmanproduce.com
event manager environment smtphost 10.100.10.70 10.100.10.71
event manager directory user policy "flash:/"
event manager session cli username "eem"
event manager applet CONFIG_CHANGE_NOTIFY
event syslog pattern ".*%SYS-5-CONFIG_I*."
action 1.2 cli command "enable"
action 1.4 cli command "show archive log config all"
action 2.0 mail server "$smtphost" to "$email_to" from "eem@$_info_routername" subject "configuration change @ $_info_routername" body "$_cli_result"
I figured it out
thank you for repsonding to my postings
