PI 3.2 Accessing Devices every 5 Minutes with polling off
Ric Hernandez
My PI 3.2 appliance is logging into my devices every 5 minutes even though I have all polling inactive.  We use switch logs to trigger alerts so when the log is full of logins from the PI 3.2 server, any useful information is wiped out.  Has anyone else seen this behavior?  I deactivate all the automatic monitoring policies.
iportuga
Avoid to disable the jobs which are needed to manage your own network.
Try to use a syslog server, for example, PI syslog server and on device side, and if required you could use the logging discriminator to suppress the desired syslog message.
Bill Longman
I have seen this same behaviour when a device has already been entered but then the credentials are changed. If you have a device in the system and then just tell it not to poll, it may still do so. You may need to delete it and re-add it in.
