EEM script on Nexus9K to send syslog if version changed
Veroniks23
hello!
i am interested to know if there is any way to create an EEM script that will send via syslog the verison of my NEXUS.
for example:
event manager applet VERISON_CHECK
event cli match "copy running-config startup-config"
-> and then i want it to execute the following command and send the result via syslog :
show ver | sec NXOS | sec nxos.
would appreciate any help, thank you.
balaji.bandi
 try this :
action 1.0 cli command "show version | in "System version:""
action 2.0 regexp "version: (.*)\r" "$_cli_result" ver
action 3.0  syslog msg "nexus currect running version $ver"
BB
Thank you for your answer!
it doesn’t work, NEXUS 9000 does not have this commands for EEM.
That’s my problem
Apologies that did not work for you, what is the error you get, the EEM I gave was in general (let me test what is not working)
EDIT: you are right that the command regex not taking, Option only has here is to use TCL or Phython.
BB
do you have network-admin user privileges on the Nexus ?
