EEM script to capture running config & transfer to FTP server at particular date & time
Could any please let me know if we could use EEM script for capturing running config and send it to FTP server at particular Time/date
We have 200 routers & want to capture running config of all routers at particular time.
Mark Malone
You could use a kron job as another option probably  easier to configure an maintain than eem script
#https://learningnetwork.cisco.com/blogs/vip-perspectives/2013/10/30/understanding-cisco-auto-archive-feature-to-backup-configuration-file
faizanelahi
As said by Mark, Kron is much easier than eem script for scheduled backups.
But if you still want to go with EEM, below is the procedure...
event manager applet "backup"
event timer cron cron_entry "0 8 15 * *"
(cron is for periodic and cron entry is based on 5 fields--Min, Hour, Date, Month, Day of week) (
Here am planning to take backup on 15th of every month at 08:00 am , any month and any day of the week...so write *
action 1.0 cli command "enable"
action 2.0 cli command "copy startup tftp:" pattern "remote host"
action 3.0 cli comamnd "IP ADDRESS of your tftp server " pattern "filename"
action 4.0 cli command ""
Here " " means just enter...
Hope it clarifies.....
Correct me if am wrong.
