EEM Script to send alerts
packetdictator
Level 2
Level 2
Hi Im seeking your assistance in creating an eem script
EEM Task
-ping the sip server every 1 minute(already done with this script)
-email the recipient "once" the Sip Server of the Sip provider doesn't respond to ping request and email again once the Sip Server of Sip Provider is responding again
i have already created variables below appreciate your advise and response.
event manager applet Check_Globe-Pldt_SIP_Trunk
event timer cron cron-entry "*/1 * * * *"
action 1.0 cli command "enable"
action 2.0 foreach host "PLDT_SIP GLOBE_SIP"
action 2.1 cli command "ping $host repeat 5 timeout 1"
action 2.2 regexp "(.*)!!!(.*)" "$_cli_result"
action 3.0 if $_regexp_result eq "1"
action 3.1 puts "$host - TRUNK UP"
action 3.2 elseif $_regexp_result eq 0
action 3.3 puts "$host - TRUNK DOWN"
action 4.0 end
event manager applet Email-PLDT-Sip-Trunk-Status-Down
event syslog occurs 2 pattern "PLDT_SIP - TRUNK DOWN" period 1
action 0.1 info type routername
action 1.0 comment "#### PLDT ####"
action 1.1 mail server "$_mail_smtp" to "$_mail_rcpt" from "sip_trunk_alert@$_info_routername" subject "PLDT SIP - TRUNK DOWN" body "PLDT SIP TRUNK IS DOWN!!!, PLEASE CONTACT PLDT"
action 1.2 syslog msg "E-mail Alert sent"
event manager applet Email-GLOBE-Sip-Trunk-Status-Down
event syslog occurs 2 pattern "GLOBE_SIP - TRUNK DOWN" period 1
action 2.0 comment "#### GLOBE ####"
action 2.1 mail server "$_mail_smtp" to "$_mail_rcpt" from "sip_trunk_alert@$_info_routername" subject "GLOBE SIP - TRUNK DOWN" body "GLOBE SIP TRUNK IS DOWN!!!, PLEASE CONTACT GLOBE"
action 2.2 syslog msg "E-mail Alert sent"
event manager applet Email-PLDT-Sip-Trunk-Status-UP
event syslog occurs 2 pattern "PLDT_SIP - TRUNK UP" period 1
action 1.1 mail server "$_mail_smtp" to "$_mail_rcpt" from "sip_trunk_alert@$_info_routername" subject "PLDT SIP - TRUNK UP" body "PLDT SIP TRUNK IS UP!!!, PLEASE TEST CALLS"
event manager applet Email-GLOBE-Sip-Trunk-Status-UP
event syslog occurs 2 pattern "GLOBE_SIP - TRUNK UP" period 1
action 2.1 mail server "$_mail_smtp" to "$_mail_rcpt" from "sip_trunk_alert@$_info_routername" subject "GLOBE SIP - TRUNK UP" body "GLOBE SIP TRUNK IS UP!!!, PLEASE TEST CALLS"
Hi Balaji,
i tested script above i created but it did not work,  so i used track instead and it is working below is the scripts sharing to the other as well
thanks for the reply though appreciated your response
track 1 ip route GLOBE_SIP_IP 255.255.255.255 reachability
delay down 10 up 10
track 2 ip route PLDT_SIP_IP 255.255.255.255 reachability
delay down 10 up 10
event track 1 state down
action 1.0 info type routername
action 1.1 comment "#### Globe SIP ####"
action 1.2 syslog msg "$Globe_Sip Trunk is Down!"
action 1.3 mail server "$_mail_smtp" to "$_mail_rcpts" from "globe_sip_trunk_alert@$_info_routername" subject "#### GLOBE SIP TRUNK IS DOWN ####" body "GLOBE SIP TRUNK IS DOWN!!!, PLEASE CONTACT GLOBE SIP TRUNK PROVIDER! for Outgoing Call use Dial 9"
action 1.4 mail server "$_mail_smtp" to "$_mail_rcpt1" from "globe_sip_trunk_alert@$_info_routername" subject "#### GLOBE SIP TRUNK IS DOWN ####" body "GLOBE SIP TRUNK IS DOWN!!!, PLEASE CONTACT GLOBE SIP TRUNK PROVIDER! for Outgoing Call use Dial 9"
action 1.5 mail server "$_mail_smtp" to "$_mail_rcpt2" from "globe_sip_trunk_alert@$_info_routername" subject "#### GLOBE SIP TRUNK IS DOWN ####" body "GLOBE SIP TRUNK IS DOWN!!!, PLEASE CONTACT GLOBE SIP TRUNK PROVIDER! for Outgoing Call use Dial 9"
action 1.6 mail server "$_mail_smtp" to "$_mail_rcpt3" from "globe_sip_trunk_alert@$_info_routername" subject "#### GLOBE SIP TRUNK IS DOWN ####" body "GLOBE SIP TRUNK IS DOWN!!!, PLEASE CONTACT GLOBE SIP TRUNK PROVIDER! for Outgoing Call use Dial 9"
action 1.7 syslog msg "E-mail Alert sent"
event track 2 state down
action 1.1 comment "#### PLDT SIP####"
action 1.2 syslog msg "$Pldt_Sip Trunk is Down!"
action 1.3 mail server "$_mail_smtp" to "$_mail_rcpts" from "pldt_sip_trunk_alert@$_info_routername" subject "#### PLDT SIP TRUNK IS DOWN ####" body "PLDT SIP TRUNK IS DOWN!!! PLEASE CONTACT PLDT SIP TRUNK PROVIDER!"
action 1.4 mail server "$_mail_smtp" to "$_mail_rcpt1" from "pldt_sip_trunk_alert@$_info_routername" subject "#### PLDT SIP TRUNK IS DOWN ####" body "PLDT SIP TRUNK IS DOWN!!! PLEASE CONTACT PLDT SIP TRUNK PROVIDER!"
action 1.5 mail server "$_mail_smtp" to "$_mail_rcpt2" from "pldt_sip_trunk_alert@$_info_routername" subject "#### PLDT SIP TRUNK IS DOWN ####" body "PLDT SIP TRUNK IS DOWN!!! PLEASE CONTACT PLDT SIP TRUNK PROVIDER!"
action 1.6 mail server "$_mail_smtp" to "$_mail_rcpt3" from "pldt_sip_trunk_alert@$_info_routername" subject "#### PLDT SIP TRUNK IS DOWN ####" body "PLDT SIP TRUNK IS DOWN!!! PLEASE CONTACT PLDT SIP TRUNK PROVIDER!"
event manager applet Email-GLOBE-Sip-Trunk-Status-Up
event track 1 state up
action 1.2 syslog msg "$Globe_Sip Trunk is Up!"
action 1.3 mail server "$_mail_smtp" to "$_mail_rcpts" from "globe_sip_trunk_alert@$_info_routername" subject "#### GLOBE SIP TRUNK IS UP ####" body "GLOBE SIP TRUNK IS UP!!!, PLEASE TEST CALLS USING Prefix 8"
action 1.4 mail server "$_mail_smtp" to "$_mail_rcpt1" from "globe_sip_trunk_alert@$_info_routername" subject "#### GLOBE SIP TRUNK IS UP ####" body "GLOBE SIP TRUNK IS UP!!!, PLEASE TEST CALLS USING Prefix 8"
action 1.5 mail server "$_mail_smtp" to "$_mail_rcpt2" from "globe_sip_trunk_alert@$_info_routername" subject "#### GLOBE SIP TRUNK IS UP ####" body "GLOBE SIP TRUNK IS UP!!!, PLEASE TEST CALLS USING Prefix 8"
action 1.6 mail server "$_mail_smtp" to "$_mail_rcpt3" from "globe_sip_trunk_alert@$_info_routername" subject "#### GLOBE SIP TRUNK IS UP ####" body "GLOBE SIP TRUNK IS UP!!!, PLEASE TEST CALLS USING Prefix 8"
event manager applet Email-PLDT-Sip-Trunk-Status-Up
event track 2 state up
action 1.1 comment "#### PLDT SIP ####"
action 1.2 syslog msg "$Pldt_Sip Trunk is Up!"
action 1.3 mail server "$_mail_smtp" to "$_mail_rcpts" from "pldt_sip_trunk_alert@$_info_routername" subject "#### PLDT SIP TRUNK IS UP ####" body "PLDT SIP TRUNK IS UP!!!, PLEASE TEST CALLS USING Prefix 9"
action 1.4 mail server "$_mail_smtp" to "$_mail_rcpt1" from "pldt_sip_trunk_alert@$_info_routername" subject "#### PLDT SIP TRUNK IS UP ####" body "PLDT SIP TRUNK IS UP!!!, PLEASE TEST CALLS USING Prefix 9"
action 1.5 mail server "$_mail_smtp" to "$_mail_rcpt2" from "pldt_sip_trunk_alert@$_info_routername" subject "#### PLDT SIP TRUNK IS UP ####" body "PLDT SIP TRUNK IS UP!!!, PLEASE TEST CALLS USING Prefix 9"
action 1.6 mail server "$_mail_smtp" to "$_mail_rcpt3" from "pldt_sip_trunk_alert@$_info_routername" subject "#### PLDT SIP TRUNK IS UP ####" body "PLDT SIP TRUNK IS UP!!!, PLEASE TEST CALLS USING Prefix 9"
balaji.bandi
what you seeing issue here ? high level script looks ok, as long as your email server access the mail relay for the router IP.
BB
Hi Balaji,
thanks
as of now no issue but my concern is weather the email alert will send continuously or just once
also is there a way that i can combine both script?
Email will be sent once the case is matched.
BB
Hi Balaji,
delay down 10 up 10
delay down 10 up 10
