eem script with double confirmation required
sjamison76
I am trying to figure out how to get around a double confirmation in an EEM script.
In the eem script, if a specific event happens, I want it to do a show tech, and copy that up to a tftp server.
The issue is it requires a double confirmation. What is the correct syntax to work on this? What do I put in the eem script to accept both?  pattern "10.1.1.1" pattern "SHOW_TECH" on a single line?
copy flash:SHOW_TECH.TXT tftp://10.1.1.1/SHOW_TECH.TXT
Address or name of remote host [10.1.1.1]?
Destination filename [SHOW_TECH.TXT]?
Joe Clarke
cli command "copy flash:SHOW_TECH.TXT tftp://10.1.1.1/SHOW_TECH.TXT" pattern "Address"
cli command "10.1.1.1" pattern "Destination"
cli command "SHOW_TECH.TXT"
