EEM Scripting not start
frankieng
Visitor
The EEM script to monitor the te0/0/0/0, Output Data Rate has amount of bps, then open the cli for some interface configuration.
After commit the EEM.tcl file
RP/0/RSP0/CPU0:ASR9K#show event manager policy registered
Tue Mar 12 02:15:58.462 HKT
No.  Class     Type    Event Type          Trap  Time Registered           Name
1    script    user    statistics          Off   Tue Mar 12 01:42:48 2013  EEM.tcl
name {ifstats-datarate} modifier_1 {Te0/0/0/0} modifier_2 {OutputDataRate}
entry_op gt entry_val {3600} exit_comb and exit_op ne exit_val {36000}
exit_time_sec 900 exit_time_nsec 0 poll_interval_sec 5 poll_interval_nsec 0
nice 0 queue-priority normal maxrun 20.000 scheduler rp_primary Secu none
persist_time: 3600 seconds,  username: cisco
RP/0/RSP0/CPU0:ASR9K#show interfaces tenGigE 0/0/0/0 | inc rate
Tue Mar 12 02:17:08.651 HKT
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 7599301000 bits/sec, 6205537 packets/sec
The ten 0/0/0/0 is overed value 3600, but the script still not run.
What is problem? attached the TCL file
6 Replies 6
Joe Clarke
The script looks okay to me (at least the ED line).  How do you know it's not running?  Is it not showing up in the event history?
Because the scripting should apply for service policy to te0/0/0/1.106 but the policy not applied to the interface.
RP/0/RSP0/CPU0:ASR9K#show policy-map interface tenGigE 0/0/0/1.106
Tue Mar 12 02:48:50.846 HKT
TenGigE0/0/0/1.106 direction input: Service Policy not installed
TenGigE0/0/0/1.106 direction output: Service Policy not installed
Therefore, it seen not start
That's what I thought.  The policy may be running, though.  Can you check the output of "show event manager history events" to see if it's getting triggered.
The platform is ASR9000 with 4.1.2, no "show event manager histroy events"
RP/0/RSP0/CPU0:ASR9K#show event manager ?
  directory         Embedded Event Manager directory information
  environment       Global variables for policies
  metric            Metric data
  policy            Policy information
  refresh-time      Refresh time for policy username's AAA taskId
  statistics-table  Supported statistics counters
  trace             Show trace data for EEM component
Enable debugging for EEM then reregister the policy (no it, commit, re-configure it, commit).  Then post the output while the output rate is sufficiently high.
See this thread.  Looks like the interface name needs to be specified in a specific way:
https://supportforums.cisco.com/message/3891999#3891999
