EEM sending a lot of mails and interface tunnel not stable
dbs-itc01
track 1 interface Tunnel74 line-protocol
event manager environment email_server 172.26.32.61
event manager environment email_from jose.mendez@dole.com
event manager environment email_to jose.mendez@dole.com
event manager applet TU74TRACK authorization bypass
event track 1 state down
trigger delay 60
action 1 cli command "enable"
action 1.1 mail server "$email_server" to "$email_to" from "$email_from" subject "CHLR1A Tunnel 74 went down" source-interface gigabitethernet 0/0/0
action 2 cli command "conf t"
action 3 cli command "interface tunnel74"
action 4 cli command "shut"
action 5 cli command "no shut"
action 6 wait 5
action 7 mail server "$email_server" to "$email_to" from "$email_from" subject "CHLR1A Tunnel 74 re-enabled please check" source-interface gigabitethernet 0/0/0
action 8 cli command "end"
First i suggest :  remove this EEM  "no event manager applet TU74TRACK authorization bypass"
then you have lot of
you have some error :
%CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=152.231.69.173, prot=50, spi=0x7F1C92AF(2132578991), srcaddr=198.217.41.252, input interface=Tunnel74
https://www.cisco.com/c/en/us/support/docs/security-vpn/ipsec-negotiation-ike-protocols/115801-technote-iosvpn-00.html
even some time the email have issue
 %HA_EM-3-FMPD_SMTP: Error occurred when sending mail to SMTP server: 172.26.32.61 : timeout error
You have multiple issue you need to sort one by one, before you enable EEM script.
BB
6 Replies 6
balaji.bandi
what is the issue, are you getting lot of emails ? or tunnel going down ?
EEM Script doing that work when ever tunnel going down ?
but in real is the Tunnel going that many times ? you need to change the script based on Syslog message and send Alerts.
Can you post show logging
BB
yes  actually lot of emails and when I check logs seems to be running many times too, do you know how can I stop this issue? take a look to this:
Feb 9 09:11:49 CLT: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=152.231.69.173, prot=50, spi=0x7F1C92AF(2132578991), srcaddr=198.217.41.252, input interface=Tunnel74
.Feb 9 09:11:49 CLT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel74, changed state to down
.Feb 9 09:11:59 CLT: %TRACK-6-STATE: 1 interface Tu74 line-protocol Down -> Up
.Feb 9 09:12:00 CLT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel74, changed state to up
.Feb 9 09:12:02 CLT: %DUAL-5-NBRCHANGE: EIGRP-IPv4 7: Neighbor 192.168.74.17 (Tunnel74) is up: new adjacency
.Feb 9 09:12:24 CLT: %HA_EM-3-FMPD_SMTP: Error occurred when sending mail to SMTP server: 172.26.32.61 : timeout error
.Feb 9 09:12:56 CLT: %TRACK-6-STATE: 1 interface Tu74 line-protocol Up -> Down
.Feb 9 09:12:56 CLT: %DUAL-5-NBRCHANGE: EIGRP-IPv4 7: Neighbor 192.168.74.17 (Tunnel74) is down: interface down
.Feb 9 09:12:56 CLT: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
.Feb 9 09:12:56 CLT: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
.Feb 9 09:12:56 CLT: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=152.231.69.173, prot=50, spi=0x712F21A5(1898914213), srcaddr=198.217.41.252, input interface=Tunnel74
.Feb 9 09:12:57 CLT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel74, changed state to down
.Feb 9 09:13:07 CLT: %TRACK-6-STATE: 1 interface Tu74 line-protocol Down -> Up
.Feb 9 09:13:07 CLT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel74, changed state to up
.Feb 9 09:13:09 CLT: %DUAL-5-NBRCHANGE: EIGRP-IPv4 7: Neighbor 192.168.74.17 (Tunnel74) is up: new adjacency
.Feb 9 09:13:32 CLT: %HA_EM-3-FMPD_SMTP: Error occurred when sending mail to SMTP server: 172.26.32.61 : timeout error
.Feb 9 09:14:03 CLT: %TRACK-6-STATE: 1 interface Tu74 line-protocol Up -> Down
.Feb 9 09:14:03 CLT: %DUAL-5-NBRCHANGE: EIGRP-IPv4 7: Neighbor 192.168.74.17 (Tunnel74) is down: interface down
.Feb 9 09:14:03 CLT: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=152.231.69.173, prot=50, spi=0x940EF01D(2484006941), srcaddr=198.217.41.252, input interface=Tunnel74
.Feb 9 09:14:03 CLT: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
.Feb 9 09:14:03 CLT: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
.Feb 9 09:14:03 CLT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel74, changed state to down
.Feb 9 09:14:14 CLT: %TRACK-6-STATE: 1 interface Tu74 line-protocol Down -> Up
.Feb 9 09:14:14 CLT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel74, changed state to up
.Feb 9 09:14:15 CLT: %DUAL-5-NBRCHANGE: EIGRP-IPv4 7: Neighbor 192.168.74.17 (Tunnel74) is up: new adjacency
.Feb 9 09:14:38 CLT: %HA_EM-3-FMPD_SMTP: Error occurred when sending mail to SMTP server: 172.26.32.61 : timeout error
.Feb 9 09:15:07 CLT: %TRACK-6-STATE: 1 interface Tu74 line-protocol Up -> Down
.Feb 9 09:15:07 CLT: %DUAL-5-NBRCHANGE: EIGRP-IPv4 7: Neighbor 192.168.74.17 (Tunnel74) is down: interface down
.Feb 9 09:15:07 CLT: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=152.231.69.173, prot=50, spi=0xF6604630(4133504560), srcaddr=198.217.41.252, input interface=Tunnel74
For now, i suggest removing EEM Scrip running, and just Monitoring SLA track 1 is the VPN really going down - when it go down what message are you getting on the logs?
when you get an email what are the SLA track 1 results?
if the tunnel really going down so frequently you need to investigate Internet/uplink is that stable?
BB
Well actually all the information for logs I just put it above this comment, I didnt check the track status in the moment because was not checking that moment.
BB
Alright then, thanks for your help.
