EEM: SNMP Event Detector not available
ddmikeollington
In 12.4(24)T4, I don't seem to have the SNMP detector in Advanced Security; however, it is present in Advanced IP Services.
Is this a known pre-requisite?  I can't seem to find any documentation or guidance from Feature Navigator that this should be the case.
Adv Sec (3845):
(config-applet)#event ?
  application  Application specific event
  cli          CLI event
  config       Configuration policy event
  counter      Counter event
  env          Environmental event
  interface    Interface event
  ioswdsysmon  IOS WDSysMon event
  ipsla        IPSLA Event
  nf           NF Event
  none         Manually run policy event
  oir          OIR event
  resource     Resource event
  rf           Redundancy Facility event
  routing      Routing event
  rpc          Remote Procedure Call event
  syslog       Syslog event
  tag          event tag identifier
  timer        Timer event
  track        Tracking object event
Adv IP Serv (2811):
  cli          CLI event
  oir          OIR event
  snmp         SNMP event
  syslog       Syslog event
  timer        Timer event
Cheers,
Mike
Joe Clarke
This is bug CSCtj01916.  The SNMP ED should have been present in all images.
Joe Clarke
Thanks, I'll look at the fixed versions and see if they fit on the router.
Cheers,
Mike
